oregonrockers
Member since July 2006
Post by oregonrockers on Jul 31, 2006 22:34:09 GMT -5
Okay, here is another newbie question. To keep from getting so many fractures in your rocks when you tumble do you need to add a lot of plastic pellets? My last batch ended up really fractured and I'm bummed. Thanks for the help! Andrea
Post by sandsman1 on Aug 1, 2006 0:12:19 GMT -5
it depends on the rock but also on the level of rock in the barrel to little and they smash each other up if you dont have enough for 2/3 full add some pellets to get there -- most people dont use pellets till after the rough grind 60/90 then they start useing them with fragile rocks like obsidian and most softer stuff you can start with pellets in 60/90 but it does slow down the grind but it's worth it for fragile rocks --- just watch your level of rock it has alot to do with the fracturs if they bang to much even solid rocks will get hurt
Roger
Post by Roger on Aug 1, 2006 18:17:27 GMT -5
It also work better if the rocks are the same size!
Dusty Bottoms
Member since August 2006
Post by Dusty Bottoms on Aug 10, 2006 7:25:48 GMT -5
Since using more plastic pellets and putting some sugar in the tumbler-charge, I have eliminated the white-dots on stones I used to get.
If stones 'fall too hard' in tumbler, you get broken and fractures.
If they 'fall just a little easier', but still too hard, you get white-marks/dots on the stones, usually more prominent on 'ends' of stones.
The idea with sugar is to thicken the water. Think of mollasses/corn syrup. By thickening the water, you cushion the stones some. It has worked out very well for me. I really love the polish I get. Add sugar (and pellets for cushion AS WELL as polishing into small areas), if you still get fractures, add more of each. Each persons 'recipe' will be different I think due to so many differences in stones. I started with equal amounts of polish-grit/pellets/sugar. And adjusted slightly as I've used them. I'll be trying/adding borax to this recipe in near future. See nice things mentioned here on this.
Some info I have heard (not tried yet), is using kerosene in place of water in the tumbler. At first, this method has 'Danger! Wil Robinson!' written all over it! Kerosene in a barrel that has a possibilty to leak, with a hot l'il motor nearby just sounds like an accident waiting to happen. However, I still think I'm going to try this method to check results. I'm going to put tumbler in a 'little-tin-shed' (ie.covered from elements) outside and try it. I wouldn't think of trying this in a house or garage. I'm planning that the damn thing WILL catch fire, and set up accordingly.
And something that I've been pondering on is Corn Starch. I'm thinking it would make a real good cushion effect. So good maybe it prevents tumbling if too much. Ever see the science experiment where the guy mixes up a bowl of white 'liquid' (water+cornstarch), you see it rolling around the bowl, then he punches! it. No splash. Cornstarch solidifies with the impact. Cornstartch will be a liquid until it is forced/apply kinetic energy to it. I'm thinking with just the right amount (which I think may be difficlt to figure out), it may make a great medium for tumbling.
The bigger the tumbler, the more chance of broken/fractures. (stones falling from a higher distance)
The faster the RPM of tumbler, the more chance of broken/fracs. (more energy being 'transffered' to barrel, into the stones = hit harder)
* ^ rotary tumblers, new vibe for polish coming, will try same in vibe and post results
Some of the things I've tried, and hope to try.
WilliamC
Member since August 2003
Post by WilliamC on Aug 10, 2006 8:14:51 GMT -5
Greetings All, As far as I can tell I'm one of the few who uses walnut shell as a filler in my tumblers. For fresh rough I don't use any, but even with rocks that are getting nicely shaped but still have rough edges and such I add some walnut shell to the 60/90 or 120/220 stage. And always to the 220, 600, and polish stages. I don't like the plastic pellets because I have to separate them before I wash off my rocks outside on my rockpile, the walnut shell is biodegradable. And for walnut shell used in the polish stages that doesn't get broken down I collect most of it and recycle for use in the grit stages. It's still a little bit hit-or-miss as to exactly how much to use, too much and the grit gets too thick for the rocks to move around much. But when I add the right amount the sludge at the end of the tumble is like a paste that coats the rocks and the rocks are free enough in the barrels to slide around. After they're shaped I don't really want them "tumbling", that is falling and banging around against each other. I'll take some pictures of the barrels before I wash them so as to show what I mean about the sludge being of the right consistency, it'll have to be next week because I'll be out-of-town this weekend and not attending to my rocks William C
Post by Jack ( Yorkshire) on Aug 10, 2006 11:32:44 GMT -5
Hi Andrea, As Dusty Bottoms (above) sugests thickening I use wall paper paste to thicken up the water to a nice goopy slurry only 1 or 2 tea level spoons to a 6 1/2 lb load, (Experiment and dont over thicken as the grinding action will thicken the mixture , a little thicker mixture helps the grinding action ,)
I also use plastic pelets (from the 2nd stage) which I find easy to float off and seperate as- I use a kitchen sieve over a bowl or plastic container to get rid of the goop first , then wash the rocks pellets in a bowl and just pour the pellets /water through the sieve again, ( the plastic pellets float ) there you are Andrea as easy as pie!!!
I had a lot of fractures on some Ameythist and rose Quartz when I first started in fact so bad I lost all in the barrel since then I have 1 - Thickened the goop 2 - Reduced the speed to 42 RPM 3 - Started using plastic pellets
hope this helps
have a good day
jack Yorkshire UK
oregonrockers
Post by oregonrockers on Aug 10, 2006 18:26:28 GMT -5
Wow! Thanks everyone for all of your great ideas! I think I'm going to print all of that info out so I can reference it easily. So, another question....I'v read around here somewhere about using rubber bands to cushion the rocks instead. Has any one ever tried this? The idea sounded feasable, but I wasn't sure about it.
I think I will start with the sugar idea..that is easy enough to do and go from there. Also the cornstartch idea might be good too. I have made that mixture before for my kids to play with. It is quiet an odd substance, liquid but solid at the same time. I think I will be passing on the kerosene though...;-)...I want to polish the rocks, not blow them (and me) up! and that is probably what would happen. I'll leave that experiment up to you Dusty Bottoms, you'll have to let me know how that turns out!
Jack, I would have never thought of wall paper paste...tell me, how did you think of that?
WilliamC...I saw a huge bag of walnut shells the other day at Harbour Freight and it reminded me of something I had read on here. It must have been a post from you. I told my husband...I think we can use that in the tumbler....I may have to go back and get it.
Okay, off I go to thicken and cushion those wonderful, lovely rocks!
Cheers,
Andrea
Dusty Bottoms
Post by Dusty Bottoms on Aug 10, 2006 22:02:01 GMT -5
umm, one of the ol' rule of thumbs for tumbling I thought was to make sure no organic material got into the barrel. Organics will get eaten by bacteria, which in turn gives off a gas, builds pressure in tumbler and you end up with leaks or popped off top.
I made this mistake years ago when beginning, leaving too much seaweed and moss on the rocks, and sher enuff, I would get leaks. Since then, I'm extremely tedious at cleaning the stone of organics before the tumble. I haven't had a leak or popped top in over 5 years (knock on wood, the tops probably just fell off all my tumblers, hehe).
What I'm wondering is if the walnut shells cause any gas/pressure problems being that it's an organic.
WilliamC, ever have any leaks? What type of tumbler?
snowdog
RIP David Fildes, aka: snowdog
Post by snowdog on Aug 10, 2006 23:21:19 GMT -5
there are some different ways of polishing too-- like doing it dry -- that is where you will find most people using the walnut shell ,or just nut shell --- there is also a corn cob media that has a polish in it --- if used dry then you don't get any gas buildup
rollingstone
Member since July 2009
Post by rollingstone on Aug 11, 2006 3:29:24 GMT -5
I suggest avoiding organic material (sugar, cornstarch, etc.) -- it only takes a few yeast or bacteria, and you've got a recipe for a barrel blow-out.
For a quick slurry, instead of fillers and additions, use less water to start, about half the recommended amount for your tumbler. Just be prepared to open the barrel after a few days to add more water (and rock), if needed. A more rapid and thick slurry should prevent your fracturing problems.
Post by Jack ( Yorkshire) on Aug 11, 2006 3:49:07 GMT -5
Hi Andrea, Wall paper paste. I read it some book or was told by the friend who gave me the tumbler & lapidary equiptment 8 years ago Jack Yorkshire UK
