riverbendlapidary
Member since September 2006
Post by riverbendlapidary on Oct 3, 2006 18:03:59 GMT -5
anyone ever tried hydraulic oil (for tractors) in a large slab saw? they have it down the street for $5/gal.
Post by cpdad on Oct 3, 2006 19:07:15 GMT -5
hey river....had a little discussion with someone i know about using different oils as coolant in saws....he basicly said that it wouldnt work real well....but there were oil (based) coolants that worked killer....but were organic and expensive....kinda like an organic veggie...expensive but good ;D
i cant find the link now he sent me....and it actually referred to cutting metal...but he said it might be worth a shot for rocks...the recipe was..
60 percent hydraulic oil(cheapest) 40 percent paint thinner
it wouldnt began to smell...the paint thinner would evaporate a little at a time...just add a little more when the coolant seemed to thicken.
plus trying straight oil would leave a slight film everywhere around the cutting area....and grit and grime would settle on anything that the oil mist settled on.
if i can find the link...i will add it later....but this dude is an engineer...ya know how that goes.......some of the smartest dumbutts i have ever met ;D
Post by Sabre52 on Oct 3, 2006 19:10:23 GMT -5
Yup, I tried the hydraulic fluid carried for tractors at Walmart. Real cheap but the project was in my case a big failure. It's pretty viscous and picked up grit and jammed the saw in the cut right quick. I guess anything used for the saw has to run just about like water. A buddy of mine made the suggestion as he uses it in his 36" drop saw with some success but I think he cuts his oil with kerosene. I've adopted the use of lots of kerosene with my oil as a money saving device and it's a great coolant for cheap! Not even very bad smelling and easy to clean off the stones. Most my buddies do this. I had some doubts about the flammability but it doesn't seem to be a problem as kerosene is hard to ignite. I've been using it about two years now. One of our big rockshops here uses straight kerosene and has for 20 years with no problems and he runs multiple saws all day long every day. I was a little worried about closed chamber gas vapor explosions too but have yet to hear of one. I keep a fire extinguisher a handy though. Fumes are a bit hard on the lungs too so I try to avoid breathing them. Cool thing is, it's readily available in 3 1/2 gal ponies for like $13.00 in paint departments everywhere....mel
Post by Jack ( Yorkshire) on Oct 8, 2006 7:38:29 GMT -5
Hi Riverbend lapidary,
I use Flushing oil it works great and is priced not to bad,
Flushing oil is used to clean the engine out of dirty oil and sooty deposits so it is well able to wrap up the stone dust it's smell isen't to bad either.
have agoodday Jack Yorkshire UK
