rockhard
Member since March 2006
Post by rockhard on Jun 29, 2006 1:45:34 GMT -5
Nephrite's pic of the cab tray makes me wonder- how else do people display their collections? I don't have any to put up yet, but won't want to just put them in a baggie in a drawer.
Post by rockyraccoon on Jun 29, 2006 8:16:53 GMT -5
if i truly wanted to display mine, i would want to commission stoner to build me a really spectacular wooden box that was as much a display piece as my stones. yep that's what i'd do!
kim
Post by Sabre52 on Jun 29, 2006 9:19:32 GMT -5
Here's what I like to use. I think they're called Riker Mounts and I get them from an outfit called Smokey Mountain Knifeworks. The one with the red velveteen liner is for Zippo lighter collectors but the separate compartments fit two 30 x40 cabs real well. I think the smaller is for coins and such. They stack well, seem to hold up pretty well and have glass tops. Not very expensive either. This will be my first crack at thumbnails. Hope it works....mel
rallyrocks
Member since November 2005
Post by rallyrocks on Jun 29, 2006 9:35:10 GMT -5
The things that I've been sold as "Riker mounts" are just a glass fronted box with fuzzy stuff inside, not seperatly compartmentalized like Mel's- but that's what I've been using.
Although I do like these that Mel has, the problem with mine is if they get tilted the thinner stones tend to slide around- maybe I should shop around a bit more....
Post by Sabre52 on Jun 29, 2006 9:55:36 GMT -5
You may be right about the name Rally. I probably don't have it right. I don't have a current catalog so I couldn't check. I do like they way the ones I use are compartmentalized. The white papers you see behind my stones don't come with the case. I cut these to fit and have identity etc on the back side so I don't forget what things are.....mel
Post by gemkoi on Jun 29, 2006 13:45:35 GMT -5
They are Riker Mounts, with "compartment trays". ANother idea ive seen at gemstone allot. Two sided tape or blue tack glue. And a sized mount or hard wood or similar craft baord. 11x14 is a good size. Stick your cabs to the board, label them, hang the baord or store it in a bin. With many other boards. My personal cabs are just displayed open on a shelf. Cabs for sale are stored in baggies.
rockhard
Post by rockhard on Jul 5, 2006 20:56:48 GMT -5
Cool, thanks. I relly like your idea of removable backing doubling as ID tags Mel.
offbeat
no posts
Member since May 2010
Post by offbeat on Jul 6, 2006 0:50:15 GMT -5
I gotta get organized. Mine are just laying all over the house! I think I am driving my wife crazy, rocks every where! Bill
rockhard
Post by rockhard on Jul 27, 2006 16:30:44 GMT -5
Hey at least if they're all ove the house, they're being seen!
I've been thinking about this. Here are a few ideas:
Glue them all to a sport jacket, covering the whole thing. Keep it hanging in the entry.
Cat-proof your draperies by the above method.
Cut the heads off a bunch of barbie dolls, glue heads to the wainscotting, and glue their hair into individual cab holders in a line all around the room.
Get one of those big purple stuffed Barney things and render it harmless- or at least less malevolenty demonic- by covering every inch with cabs in hot glue.
Cover normally non-decorative surfaces that everyone will see on every visit, such as the toilet tank, with cabs.
Hot glue to angel hair tinsel as Yule tree ornaments.
Sort by color, then fill oddly shaped bottles and jars with them in layers. Top off with olive oil and a hot pepper, and tie a marthastewartish bow 'round. Display anywhere except in kitchen.
In the kitchen, cover the countertop with them, then pour a layer of that clear acrylic they used to make paperweights out of dried bugs and snakes with in the 70's.
Do the above with every other flat surface in the house.
Then make a hobby car covered in cabs. Be sure to use weatherproof cement. And leave a little of the front and rear glass uncovered...
Line the bottom of an aquarium with cabs instead of gravel. Be sure not to use copper based minerals if you plan to keep fish.
Put them into one of those machines that continually rolls them down spirals, lifts them on belts and in cups, drops them down seesaws, etc.
Attach them to masquerade party masks, and make everyone wear them while visiting.
Render a portrait of the US President of your choice, in coprolite cabs.
OK so I wasn't really thinking about it. But it helped pass the time instead of being annoyed that I'm still sitting here waiting for the damn customer to unload their sh-tuff.
Post by Sabre52 on Jul 29, 2006 0:29:08 GMT -5
*L* Rock you've got a great imagination. I was actually at a jewelry store once that had a showcase full of cabs in little long trays that rotated like a water wheel coming under the lights in sequence. If I had any mechanical skill I'd build one as that thing was so kewl!!! Held a huge number of cabs and really showed them off well....mel
Post by rocklicker on Jul 29, 2006 19:39:02 GMT -5
Uh oh, the gears in my head are turning again. Steve
