evolutoin
Member since October 2008
Post by evolutoin on Oct 10, 2008 13:39:19 GMT -5
Hello Everone I am new to the forum and just starting at tumbling. My question is can I tumble granite? I have tons of scrap granite from my countertop shop and am sick of throwing it in the garbage. Thank you in advance Nate
randy
Member since August 2008
Post by randy on Oct 10, 2008 14:03:20 GMT -5
I would think so. Your countertops sure have a nice polish. Can't see why a tumbler would be any different at getting a high polish. You might get a little bored after awhile if you were to tumble only granite though. Worst case, give it a try and it doesn't go well. Good luck.
Post by Bikerrandy on Oct 10, 2008 16:15:18 GMT -5
Yes, you can. Granite is soft though, so it would tumble better without other kinds of rock I think, but I've read on here that it will polish nicely.
Post by Toad on Oct 11, 2008 8:19:29 GMT -5
Yep, it tumbles well and you can get a polish. But it has variable hardness and so pits and undercuts easily. The nice thing about granite though is that it comes in great varieties.
Post by krazydiamond on Oct 11, 2008 8:23:00 GMT -5
yeh, don't throw it in the garbage! in fact, what kind of scrap do you have? got any to sell?
KD
KG1960
Post by KG1960 on Oct 12, 2008 21:05:28 GMT -5
Yes you can. I have done it. As others have pointed out, the grains can be variable hardness and the final result can have an "orange peel" effect, but I think it's quite interesting and nice.
88pathoffroad
Oregon ROCKS!
Post by 88pathoffroad on Oct 18, 2008 13:54:42 GMT -5
I picked up a ton of brown granite scrap from some guys that did some custom countertops on some bi-level condos I helped paint. Must have been 75 lbs of it...I broke it into 1" or 2" chunks (it was about 1/2" thick to begin with) and used it for filler on rough, medium and then a polish run. It took a polish on the quartz grains but the feldspars were blurry and unfinished. Altogether it didn't work out too well. I just use the chunks for filler now.
gatorflash1
Post by gatorflash1 on Jan 13, 2020 20:14:05 GMT -5
Post by aDave on Jan 13, 2020 20:26:34 GMT -5
The OP hasn't been on since 2008.
whyofquartz
So, Africa is smaller than I expected...
Member since December 2019
Post by whyofquartz on Jan 14, 2020 11:50:20 GMT -5
Even though you resurrected this thread it is good info to have since I have purloined acquired come to be in possession some rail granite if my own, as well as some other wild granite
EricD
High in the Mountains
Member since November 2019
Post by EricD on Jan 14, 2020 13:59:48 GMT -5
I've got a bunch more in the rotary that will get polished as rocks, not slabs. I also happened upon some railroad granite somehow...
Will post some pics of them in a couple months.
Post by RocksInNJ on Jan 14, 2020 17:08:00 GMT -5
Yea while distracted by the rocks, he forgot to untie the damsel in distress from the tracks. Luckily I was flying by and abducted saved the poor girl.
