unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on Sept 3, 2011 8:14:42 GMT -5
Hi all, Perhaps some of you might remember a few months ago when I was in the process of getting started with cabbing. I asked a lot of questions about trim saws and I picked the rock rascal model J. Well it has been a few months (3 or 4) and I would like to give a quality update. When the model J arrived it did so without any instructions, warranty paper work owners manual. Through the efforts of some of you and Kingsley North I was able to get that info. The saw looked to be a well made (all metal construction) and simple in design. I would have been happier with a larger work table without a raised lip so as to be able to handle larger slabs.
I consider myself to be a light duty occasional user of this saw and am very disappointed in the quality of the finish and that of the power switch. The paint has lifted off of the work table and the plastic on/off in-line switch has crumbled as a result of vibration. Other than these issues the saw is OK. I will call Dan at Kingsley and the manufacturer and see what happens. If they can send me a new power cable and work table in exchange for the broken/defective parts that would be OK. Otherwise I will pick up a new power cord/switch and a can of black paint at HD Stu
Post by FrogAndBearCreations on Sept 3, 2011 9:27:33 GMT -5
You just might look into getting a tile saw to cut up those larger slabs that do not fit on the RR trim saw.
I have one that I picked up from HD on sale for 30 bucks - a little 4" blade tile saw that I can cut up larger slabs on. The table will accomodate the 8" x 8" tiles easily and possible the 12 x12 inch too.
It has lasted me a long time with lots of use as for a while it was my only saw for preforming the slabs I bought off of ebay when I first got into this hobby
Post by johnjsgems on Sept 3, 2011 11:31:52 GMT -5
Make sure the 4" tile saw has a 5/8" arbor and use 4" lapidary blades. It will out cut any lapidary small saw for trimming slabs. I'm not a fan of Rock Rascal but any saw that has a painted table will lose paint quickly when you start cutting.
Post by Rockoonz on Sept 3, 2011 22:42:23 GMT -5
I agree with John, betwiin the coolant additives and the sharp little shards of rock the paint on a saw table never lasts long. When I rebuild old saws I don't ever paint the table top. I really don't like the inline power switches either.
Lee
Lee
neilshoe
Member since February 2019
Post by neilshoe on Feb 16, 2019 12:35:21 GMT -5
I don't have an answer to your question but I just purchased a Rock Rascal J model and was wondering if you use a coolant or just water to cool the blade?
inbtb
Member since May 2016
Post by inbtb on Feb 16, 2019 13:01:14 GMT -5
Use baby oil for coolant.
Les
Post by Rockoonz on Feb 16, 2019 13:09:17 GMT -5
I don't have an answer to your question but I just purchased a Rock Rascal J model and was wondering if you use a coolant or just water to cool the blade? Definitely not straight water, but on a 6 inch saw it is permissable to use water with an additive instead of oil. The saw blade manufacturer list: www.barrancadiamond.com/pdf/tec/bd_slab_saw_coolants.pdf
daxm
Member since February 2020
Post by daxm on Feb 4, 2020 11:47:48 GMT -5
Hi I recently bought the same saw from kingsley as well and I can also confirm that it came with no manual or instructions at all. I'm trying to find a manual for the machine to know how to access the pan for coolant/Oil without breaking it. Do any of you know how to remove the cover so I can fill the pan or check the level of fluid in the pan?
Post by knave on Feb 4, 2020 12:21:52 GMT -5
Post by rockjunquie on Feb 4, 2020 12:58:54 GMT -5
Post by quartz on Feb 5, 2020 0:03:38 GMT -5
The page knave put up just mentions the flathead screw, not its location. It's between the blade and the right side of the saw, right over the arbor shaft. When I bought mine, used, the slot in the screw was packed so solid with saw leavings it was hard to spot.
Post by Peruano on Feb 5, 2020 9:36:42 GMT -5
I had a model t which I never reinstalled the screws after removing them. The top never u Just off and it was easy to clean. Instructions?
