Post by Woodyrock on Nov 19, 2013 1:56:24 GMT -5
I bought a stack at Q a couple of years back. Woody
Tom
Post by Tom on Nov 19, 2013 7:25:59 GMT -5
As bobby1 says, get bars from Bob Lewis. Perfect and a fair price. you have to be able to slab them or have them slabed.
Tom
Post by connrock on Nov 22, 2013 8:52:58 GMT -5
Bobby,,, Thanks,,,man am I ever getting an education here! connrock
Post by orrum on Nov 22, 2013 9:15:47 GMT -5
So if its slabbed for a cap on a cab how do you get it clear? Do you flat lap the slabs to polish them before glueing on the cab? Do you flat lap thThanks, Bille top of tge cab b4 glueing? What kinda glue is gonna be as optically clear as the quartz?
gemfeller
Member since June 2011
Post by gemfeller on Nov 22, 2013 14:47:38 GMT -5
So if its slabbed for a cap on a cab how do you get it clear? Do you flat lap the slabs to polish them before glueing on the cab? Do you flat lap thThanks, Bille top of tge cab b4 glueing? What kinda glue is gonna be as optically clear as the quartz? Some may disagree but I've made a lot of Spencer opal triplets and this approach worked well for me: just grind both the cab surface and the quartz slab flat to about 600 grit; they need not be polished. Epoxy 330 worked well for me to create a "window" for the unpolished quartz. I have triplets I cut 30 years ago that are still strongly bonded. I haven't experimented with some of the newer adhesives like Hxtal or UV-activated glues. The only problems I had with 330 were bubbles and gravity. After mixing I'd warm it gently under a light bulb to make it more fluid. After putting the quartz in place I'd use top pressure to force the bubbles out, then held it in place with a wooden clothespin or a weight to keep it from moving during the 24 to 36-hour drying time. Rick
godloveme88
Member since October 2017
Post by godloveme88 on Oct 27, 2017 21:27:22 GMT -5
I could probably cut you some if you need them, I think I still have a few points left that are big enough to slab. Let me know what sizes and how many you need. Tony
godloveme88
Post by godloveme88 on Oct 27, 2017 21:28:01 GMT -5
Hello,Tony.Could you please contact me? Thank you.
godloveme88
Post by godloveme88 on Oct 27, 2017 22:29:02 GMT -5
Post by catmandewe on Oct 28, 2017 10:51:42 GMT -5
godloveme88 I dont think I have any more clear quartz points big enough to slab up. I will check sometime this week in case I am wrong. Tony
godloveme88
Post by godloveme88 on Oct 28, 2017 12:49:50 GMT -5
Thanks
Post by Deleted on Oct 28, 2017 13:44:06 GMT -5
If you only need 1 or 2, there is also the option (if you aren't doing giant-size cabs) of using watch crystals for caps. They come in fused quartz mineral glass, spinel and sapphire from most any watch repair catalog or on-line parts site. A bit more expensive (especially for spinel/sapphire), tho.
godloveme88
Post by godloveme88 on Oct 28, 2017 21:54:54 GMT -5
godloveme88 I dont think I have any more clear quartz points big enough to slab up. I will check sometime this week in case I am wrong. Tony Thanks!
godloveme88
Post by godloveme88 on Oct 28, 2017 21:55:35 GMT -5
If you only need 1 or 2, there is also the option (if you aren't doing giant-size cabs) of using watch crystals for caps. They come in fused quartz mineral glass, spinel and sapphire from most any watch repair catalog or on-line parts site. A bit more expensive (especially for spinel/sapphire), tho. Thanks! Could you please show me some examples?
Post by 1dave on Oct 29, 2017 0:41:41 GMT -5
