Post by 1dave on Nov 28, 2013 12:57:18 GMT -5
By rockpowell : A VERY EXPENSIVE LESSON - Watch out for fractures!
Post by catmandewe on Nov 28, 2013 13:12:08 GMT -5
Now you have a notched rim blade!
Post by Fossilman on Nov 28, 2013 13:20:56 GMT -5
OUCH $$$!!!!!!!
Post by mohs on Nov 28, 2013 13:53:08 GMT -5
that's 220 karat ouch mohs
QuailRiver
Post by QuailRiver on Nov 28, 2013 13:59:43 GMT -5
I have heard that this type of damage to the rim of a diamond blade can be repaired with a tig braze with a silicon bronze filler rod. And then grinding the repair down flush with the rest of the rim of the blade. Larry C.
Post by Sabre52 on Nov 28, 2013 16:22:56 GMT -5
Yikes! been there done that. Arizona pet wood is a famous bade breaker and that's the one that got me.....Mel
gemfeller
Member since June 2011
Member is Online
Post by gemfeller on Nov 28, 2013 17:49:27 GMT -5
Happened to me last week with a chunk of agate. Fortunately the blade locked up, stopped the motor and the motor's overheat protection kicked in and shut it down. I was able to untangle the mess without blade or motor damage. But I sure pay attention when I hear funny noises while tightening the vise!
Post by jamesp on Nov 28, 2013 18:49:47 GMT -5
I wonder if that gap will hurt anything? I do see more fractures to the right of the gap in the first photo. Correct me if i am wrong but i am fairly sure they are there.
Post by phil on Nov 28, 2013 20:26:51 GMT -5
take a file and smooth (round) off that area, and you'll still be able to use the blade as long as it isn't bent. But remember, it will now cut you too.
rockpowell
Have been rock hunting most of my life, love cutting rocks, have tons of slabs, just haven't posted
Member since February 2013
Post by rockpowell on Nov 29, 2013 7:21:31 GMT -5
I wonder if that gap will hurt anything? I do see more fractures to the right of the gap in the first photo. Correct me if i am wrong but i am fairly sure they are there. rockpowell Yes there are fractures after the chunk out, but it feels quite solid, Did try and cut with it after an oil and new Fafnir bearings, there was a noise and slight vibration. So I went back to the old mk 303 blade. No noise, just to check the new bearing sound. Never thought of the blade beaning welded, Have a friend that could do that for me as the blade was new and only used for 3 mo. Will try it and let you know how it turns out. It was a 14" black covington. Thanks ! 1dave hunting buddy.
Post by phil on Nov 29, 2013 15:08:30 GMT -5
You also need to oil that blade after you're finished to keep that rust off. Rust can weaken a blade rapidly.
Post by 1dave on Jul 30, 2017 14:49:24 GMT -5
