catskillrocks
Member since July 2008
Post by catskillrocks on Jan 4, 2016 21:45:47 GMT -5
Does anyone have suggestions for making stone dice? I want to try to make some dice for family members who play Dungeons & Dragons. There would be a 20 sided die, 12, 10, 8, 6 & 4 sided. Is this an impossible feat, or has anyone done this. Any help would be appreciated.
Thanks,
Don
rockroller
Be excellent to each other.
Member since October 2013
Post by rockroller on Jan 4, 2016 21:51:02 GMT -5
I've often thought of doing the same thing but it seems to me that besides normal dice, six siders, you might need a faceting machine?!
Hope someone has better info.
Roland
Post by mohs on Jan 4, 2016 22:01:24 GMT -5
as some one a picture of one these D & D dice?
catskillrocks
Post by catskillrocks on Jan 4, 2016 22:13:48 GMT -5
cobbledstones
Member since January 2014
Post by cobbledstones on Jan 4, 2016 22:27:47 GMT -5
Post by Deleted on Jan 4, 2016 23:06:56 GMT -5
I've often thought of doing the same thing but it seems to me that besides normal dice, six siders, you might need a faceting machine?! Hope someone has better info. Roland thats funny you say that Roland.when I told my helper(who plays D&D)that I was getting a Faceting machine that's the first thing that popped out of his mouth.not the most cost effective tool for dice production but precise to say the least. Dave
Post by mohs on Feb 14, 2016 20:05:05 GMT -5
Hi Guys This is a project I got fairly obsessed by its an 18 sides faceted die I created it by basically epoxing to 2 pyramid together Take a cube cut diagonally creates 2 pyramids turn pyramid 90 degrees & epoxy the bottoms together grind the 8 points flat and the tops of the pyramids 18 facets. my project isn’t finished and I forget I had a flat lap ha ha when I ground the points that would have greatly assisted in the flats Plus I need to do some touch up buffing and this is a lousy picture do to the brightness of the sun I’ll take some later this evening but its Dark Side of the Moon project on second thought maybe I shouldn’t have ground 2 pyramid tops?
Post by Fossilman on Feb 14, 2016 21:26:25 GMT -5
Lot of work Ed!!!!!!!!!!!!
Post by mohs on Feb 14, 2016 21:30:07 GMT -5
you make cubes... right Mike? a little better picture and while I was taking that I took a picture of the sunset reflected building at the end of Polk St. It really fabulous and I think it orientated for maximum effect during Summerset equinox
