sdrockgal
Member since December 2016
Post by sdrockgal on Dec 31, 2016 12:26:23 GMT -5
I've been practicing a bit on rough rock. This is my first wrap with tumbled rock. It's soldered on the back to keep it tight. Just used cheap copper wire. I like having the hole drilled in. It makes it feel more secure. I welcome feedback. Thanks for looking!
shermandukejewelry
Retired, learning jewelry design
Member since July 2016
Post by shermandukejewelry on Dec 31, 2016 14:43:58 GMT -5
I like it.
Post by tims on Dec 31, 2016 14:47:45 GMT -5
Looks nice. Kind of primitive and elegant at the same time.
Post by Fossilman on Dec 31, 2016 15:02:32 GMT -5
Great job........I like the simple wraps,the rock showing more than the wire,,... Thumbs up on a great wrap!
sdrockgal
Post by sdrockgal on Dec 31, 2016 16:53:07 GMT -5
Thanks everyone. I hope to have more to share soon.
TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Dec 31, 2016 21:20:01 GMT -5
Looks good, my only suggestion is that your bail needs to go the other direction or you need to add a larger jump ring to it. The reason for this is so that it will lay flat when you put it on a chain. Great job for a first wrap.
sdrockgal
Post by sdrockgal on Jan 1, 2017 0:11:05 GMT -5
Looks good, my only suggestion is that your bail needs to go the other direction or you need to add a larger jump ring to it. The reason for this is so that it will lay flat when you put it on a chain. Great job for a first wrap. Good suggestion. I wonder if I could twist it without breaking the solder on the back? I'll have to play with it a bit.
Post by wigglinrocks on Jan 1, 2017 1:04:28 GMT -5
Yeah , what Fossilman said . I prefer the more simple wraps , like looking at rocks , not wire .
Post by rockjunquie on Jan 2, 2017 12:42:03 GMT -5
Great way to wrap a tumble. Odd shapes are more of a challenge, but you can make some cool wraps with them.
metalsmith
Post by metalsmith on Jan 3, 2017 2:38:13 GMT -5
Looks good, my only suggestion is that your bail needs to go the other direction or you need to add a larger jump ring to it. The reason for this is so that it will lay flat when you put it on a chain. Great job for a first wrap. Good suggestion. I wonder if I could twist it without breaking the solder on the back? I'll have to play with it a bit. Yeah, probably. So long as you made a decent job of it, soldered silver is pretty solid. If it is 'biscuit' that's because the join didn't form. It should take a 90 degree rotation no trouble. Of course, your pendant could be worn on leather in a similar way to that presented. That's a good first wrap btw!
sdrockgal
Post by sdrockgal on Jan 3, 2017 7:49:41 GMT -5
Thanks! I did end up leaving it the way it is. I like that it doesn't slide on the cord.
