Post by melhill1659 on Feb 14, 2017 1:03:55 GMT -5
Had some trouble with this cab later today during the polishing stage. A small piece decided to brake but since it's for me...
Post by MrP on Feb 14, 2017 5:41:02 GMT -5
melhill1659 I like the style of this wrap. I never thought of capturing the wires different, front vs back..............................MrP
Post by Drummond Island Rocks on Feb 14, 2017 7:54:43 GMT -5
Congrats on getting that first one done. I still have my first couple stashed away.
Post by melhill1659 on Feb 14, 2017 8:54:33 GMT -5
Side/backish view
Post by rockjunquie on Feb 14, 2017 9:51:02 GMT -5
Looks great! Very neat. You really can't tell the stone broke, either.
Post by Fossilman on Feb 14, 2017 10:21:43 GMT -5
Very very nice wrap! Simple,but to the point!! The way it's incorporated is beautiful...Nicely done!
TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Feb 14, 2017 16:00:40 GMT -5
Great job. I love how you used the wider wires in between the front and back wires.
Post by melhill1659 on Feb 14, 2017 17:37:57 GMT -5
Thanks Guys!! Oh an if ANYONE has any tips or constructive criticism's , don't ever hesitate to chime in. Playing with the earrings now!
Roger
Post by Roger on Feb 14, 2017 23:22:37 GMT -5
Much, much, nicer than my first wraps. Very nice job on the bail. It took me a lot of wraps before I ever made a bail that looked complete. Can't wait to see the earrings!
Post by melhill1659 on Feb 15, 2017 15:26:33 GMT -5
Post by melhill1659 on Feb 15, 2017 15:27:12 GMT -5
My homemade earring holder turned out great!
Post by rockjunquie on Feb 15, 2017 15:53:33 GMT -5
I like those! I like that style earwire, too. What gauge did you use on them? BTW- in case you didn't know- twisted wire earwires are often called "non- slip earwires". I should mention- not to nit pick, but it is my own anal pet peeve- when you cut a wire, try to get into the habit of cutting with the flat side of the cutters. It will cut more flush that way. Sorry, I'm not trying to be negative- because there is nothing negative about your early effort, AT ALL. But, you asked, so I thought I would say.
Post by melhill1659 on Feb 15, 2017 20:55:25 GMT -5
I like those! I like that style earwire, too. What gauge did you use on them? BTW- in case you didn't know- twisted wire earwires are often called "non- slip earwires". I should mention- not to nit pick, but it is my own anal pet peeve- when you cut a wire, try to get into the habit of cutting with the flat side of the cutters. It will cut more flush that way. Sorry, I'm not trying to be negative- because there is nothing negative about your early effort, AT ALL. But, you asked, so I thought I would say. I appreciate any tips, Thank You. I WILL GET THIS 😂😂 I see what you're talking about now. I'll get my file out.
Post by pghram on Feb 16, 2017 18:08:17 GMT -5
That's a very nice set. I also like the thicker wire for the frame.
Peace,
Rich
Post by melhill1659 on Feb 16, 2017 20:15:47 GMT -5
That's a very nice set. I also like the thicker wire for the frame. Peace, Rich Thank You!
Post by paulshiroma on Feb 16, 2017 20:56:16 GMT -5
*** APPLAUSE ***
Came out beautiful! Nice job.
Post by melhill1659 on Feb 17, 2017 19:20:06 GMT -5
I like those! I like that style earwire, too. What gauge did you use on them? BTW- in case you didn't know- twisted wire earwires are often called "non- slip earwires". I should mention- not to nit pick, but it is my own anal pet peeve- when you cut a wire, try to get into the habit of cutting with the flat side of the cutters. It will cut more flush that way. Sorry, I'm not trying to be negative- because there is nothing negative about your early effort, AT ALL. But, you asked, so I thought I would say. I used 18gauge on those
Post by rockjunquie on Feb 18, 2017 12:32:25 GMT -5
I like those! I like that style earwire, too. What gauge did you use on them? BTW- in case you didn't know- twisted wire earwires are often called "non- slip earwires". I should mention- not to nit pick, but it is my own anal pet peeve- when you cut a wire, try to get into the habit of cutting with the flat side of the cutters. It will cut more flush that way. Sorry, I'm not trying to be negative- because there is nothing negative about your early effort, AT ALL. But, you asked, so I thought I would say. I used 18gauge on those 18 for the wires, too? That's a bit unusual. It's usually 20g and sometimes 22g.
Post by melhill1659 on Feb 18, 2017 20:15:51 GMT -5
It was so twisty an purdy 🙈 Tela, probably why I had such a hard time getting it to mind huh...
Post by rockjunquie on Feb 18, 2017 20:18:52 GMT -5
It was so twisty an purdy 🙈 Tela, probably why I had such a hard time getting it to mind huh... 18g is fine for a wrap. I was talking about the earwires. The gauge is a bit big for comfortable earwires. Looks like you had perfectly good control over the wire.
