Post by rockjunquie on Feb 16, 2017 15:44:15 GMT -5
I have had these nice big charoite beads for a long time and could never find gold filled caps big enough, so I got some sheet and planned to make some. Well, I was really hesitant to use the gold because I was afraid to mess up. I put it off for a couple months now. But, I got the nerve up today after someone gave me some gentle encouragement yesterday. Thanks, Garage Rocker . I did a few copper ones for practice and then it was a cinch. I know this isn't much, but it just goes to show, sometimes you just have to jump into it. These are just on a temporary wire for the pictures. They are going to be simple earrings and a pendant.
Post by woodman on Feb 16, 2017 16:18:16 GMT -5
Real nice job!!!
fireforged
Member since December 2015
Post by fireforged on Feb 16, 2017 16:20:02 GMT -5
I have been there. Have never had the courage to even order gold metal for a project. I have had projects wait for months even years before I have had the courage to finally do them and afterwards I ask why was that so hard?
Your project looks beautiful. Can you even tell me what the hold up was?
Post by rockjunquie on Feb 16, 2017 16:35:06 GMT -5
I have been there. Have never had the courage to even order gold metal for a project. I have had projects wait for months even years before I have had the courage to finally do them and afterwards I ask why was that so hard? Your project looks beautiful. Can you even tell me what the hold up was? Thanks. I don't know if that was rhetorical, but I have an answer anyway. I have a small work area, so part of the problem was I knew I had to tear everything out and put it back, so there was that bit of laziness. Plus, I haven't used the disc cutter and dapping block very often, so I didn't feel all that confident doing it with gold. Then there is the other side of laziness knowing that I had to make a bunch of copper ones (and dig out all of my copper to find the right gauge) to work out the size that I wanted. I haven't made end caps before and only rarely have ordered them as I don't usually work with beads. I guess it was a combination of a bit of laziness and treading in uncharted territory.
Post by Garage Rocker on Feb 16, 2017 16:57:46 GMT -5
Sometimes we need a gentle nudge and sometimes a giant shove, but the dread is always worse than the action. Glad you jumped in, they are as perfect as I knew they would be.
Post by Deleted on Feb 17, 2017 10:38:02 GMT -5
Are u kidding me?
She is a goldsmith now?
Awesome Tela!! Those are amazing!
Love to see gold. Love it!
Post by Fossilman on Feb 17, 2017 10:54:45 GMT -5
WOW,you did great!!! Two thumbs up!!
NDK
Post by NDK on Feb 17, 2017 10:57:34 GMT -5
I love charoite. Looks great with gold!
Post by rockjunquie on Feb 17, 2017 11:19:04 GMT -5
Are u kidding me? She is a goldsmith now? Awesome Tela!! Those are amazing! Love to see gold. Love it! Well, technically, it's gold fill. If it had been solid gold, I may NEVER have gotten around to it. LOL!
Post by rockjunquie on Feb 17, 2017 11:19:53 GMT -5
I love charoite. Looks great with gold! I know, right? When I got these, I knew it had to be gold. I love charoite and gold!
Post by Deleted on Feb 17, 2017 11:26:10 GMT -5
I love charoite. Looks great with gold! I know, right? When I got these, I knew it had to be gold. I love charoite and gold! Tela, Those are remarkable. I would be so proud of I had made those. Really well done. I'm so happy for you.
Post by orrum on Feb 17, 2017 11:36:40 GMT -5
X2 Tela is a GOLDSMITH extrodinair!
Post by rockjunquie on Feb 17, 2017 11:39:06 GMT -5
Y'all rock! Thanks so much! I almost didn't post this because it doesn't seem like much. It's the gold that made it a challenge, not that it is harder to work, just harder to work WITH. Nerve wracking. LOL!
Post by Deleted on Feb 17, 2017 12:16:44 GMT -5
Are u kidding me? She is a goldsmith now? Awesome Tela!! Those are amazing! Love to see gold. Love it! Well, technically, it's gold fill. If it had been solid gold, I may NEVER have gotten around to it. LOL! Interesting. So how do you hide the silver base exposed when punched? Or does punching do that for you? Did u solder the two little cups into beads?
Post by rockjunquie on Feb 17, 2017 12:22:31 GMT -5
The tools I use are pictured. You may be confused by the gold filled beads that separate the beads. First, I find and mark the jeweler's brass side, which looks an awful lot like gold, then I punch out the right size disc with the punch. I punch the brass side. Then I form the cup with the dapping block. I do this with the brass on the inside.
Post by Deleted on Feb 17, 2017 12:38:30 GMT -5
The tools I use are pictured. You may be confused by the gold filled beads that separate the beads. First, I find and mark the jeweler's brass side, which looks an awful lot like gold, then I punch out the right size disc with the punch. I punch the brass side. Then I form the cup with the dapping block. I do this with the brass on the inside. I assumed you made the beads. Brass under gold. And when dapped the brass isn't visible? Coolio. I assumed gold over silver. Should cost same as silver the brass way.
Post by melhill1659 on Feb 17, 2017 22:44:10 GMT -5
Sometimes we need a gentle nudge and sometimes a giant shove, but the dread is always worse than the action. Glad you jumped in, they are as perfect as I knew they would be. I second that!!!
Post by rockjunquie on Feb 18, 2017 12:40:48 GMT -5
The tools I use are pictured. You may be confused by the gold filled beads that separate the beads. First, I find and mark the jeweler's brass side, which looks an awful lot like gold, then I punch out the right size disc with the punch. I punch the brass side. Then I form the cup with the dapping block. I do this with the brass on the inside. I assumed you made the beads. Brass under gold. And when dapped the brass isn't visible? Coolio. I assumed gold over silver. Should cost same as silver the brass way. Nope, I didn't make the beads. Wish I could. So, now you know why I didn't think it was too impressive. LOL! Gold over silver would be vermeil. en.wikipedia.org/wiki/Vermeil Costs much more. Gold fill is a lifetime product with proper care. It isn't like electroplate or a coating. It is a layer of gold which is bonded to the base. I have a locket over 100 years old that still looks great.
