Post by radio on Feb 21, 2017 20:23:43 GMT -5
Post by toiv0 on Feb 21, 2017 23:23:55 GMT -5
Interesting piece, and cool repair
Post by rockjunquie on Feb 22, 2017 9:17:19 GMT -5
Your work is fabulous!!! How were you ever able to match that so well? You must have a nice stash.
Post by radio on Feb 22, 2017 9:31:16 GMT -5
Your work is fabulous!!! How were you ever able to match that so well? You must have a nice stash. LOL! Thanks. I "might" have a bit of Turquoise "stashed" I have been working with it since the mid 90's and have bought a good bit over the years. The trick is to establish relationships with folks who have earned your trust and rarely buy from anyone else unless it is an in person transaction where you can see what you are buying. I also have a special "stash" of very old material that I save from larger pieces where I have replaced broken stones. Often the broken stones can be re cut into smaller ones to match existing stones in vintage jewelry. Never throw away Turquoise!
NDK
Post by NDK on Feb 22, 2017 18:58:29 GMT -5
Way cool!
zekesman
Member since May 2016
Post by zekesman on Feb 23, 2017 15:09:26 GMT -5
Do you not feel the Devcon is just another glue. Will it not fail over time? Vic
Post by pghram on Feb 23, 2017 18:20:26 GMT -5
Do you not feel the Devcon is just another glue. Will it not fail over time? Vic X2, just curious. Well done, I would never have known that it was repaired. Peace, Rich
Post by radio on Feb 23, 2017 18:54:57 GMT -5
Do you not feel the Devcon is just another glue. Will it not fail over time? Vic I use Devcon plastic steel, not a clear epoxy resin, so it's on a different level than "glue". I seriously doubt it would degrade in 100 years! There have been Caterpiller bulldozer engine blocks patched with this stuff! Just to be clear, I will use the plastic steel to repair previously glued in stones, but do not make jewelry that I can not bezel set. I see way too many pieces that are missing stones that were set with clear epoxy and I have vowed I will never use the stuff!
zekesman
Post by zekesman on Feb 23, 2017 19:42:43 GMT -5
Do you not feel the Devcon is just another glue. Will it not fail over time? Vic I use Devcon plastic steel, not a clear epoxy resin, so it's on a different level than "glue". I seriously doubt it would degrade in 100 years! There have been Caterpiller bulldozer engine blocks patched with this stuff! Just to be clear, I will use the plastic steel to repair previously glued in stones, but do not make jewelry that I can not bezel set. I see way too many pieces that are missing stones that were set with clear epoxy and I have vowed I will never use the stuff! [ Thanks. Vic
metalsmith
Post by metalsmith on Feb 24, 2017 3:19:40 GMT -5
A good fix and lovely ring. There's also a good chance the turquoise will green over time to match the 'odd' piece.
Post by Fossilman on Mar 3, 2017 16:26:48 GMT -5
Great repair job and liking that setting and all............
