zekesman
Member since May 2016
Post by zekesman on Mar 1, 2017 13:08:04 GMT -5
Small Indian blanket jasper with twist wire in shank. Vic
zekesman
Post by zekesman on Mar 1, 2017 13:09:13 GMT -5
Shank detail
NDK
Post by NDK on Mar 1, 2017 19:52:19 GMT -5
Another nice piece. Good job on the photos too. Looks like you've got it dialed in.
fireforged
Member since December 2015
Post by fireforged on Mar 1, 2017 21:04:39 GMT -5
Love the shank. If you don't mind I want to use this in my own work.
Post by melhill1659 on Mar 1, 2017 21:25:04 GMT -5
It's beautiful!! I've been trying to wear the soldering hat this past week and the only thing I accomplished was to brake the tip off of my beautifully self cabbed Rhodochrosite!!! Urrrrr
zekesman
Post by zekesman on Mar 1, 2017 21:49:18 GMT -5
Love the shank. If you don't mind I want to use this in my own work. No problem. Most of my stuff is "inspired by others" lol
zekesman
Post by zekesman on Mar 1, 2017 22:05:04 GMT -5
It's beautiful!! I've been trying to wear the soldering hat this past week and the only thing I accomplished was to brake the tip off of my beautifully self cabbed Rhodochrosite!!! Urrrrr What was the problem you had? Was the bezel too tight after you soldered it? We can probably help you work through some issues if we know what they are. I am by no means an expert, but there is a lot of collective knowledge on the board. Vic
Post by melhill1659 on Mar 1, 2017 23:27:53 GMT -5
Was using a SS step bezel. I think I pushed to hard. Guess I should play around with cheaper material first to build my skills. The crazy setting will look better with a shallow jasper anyway!
Post by Pat on Mar 1, 2017 23:44:09 GMT -5
Might help to file ss corners down a bit. Less pressure.
That's a nice design and lovely rhodochrosite.
Post by pghram on Mar 2, 2017 13:22:44 GMT -5
Another beautiful ring!
Peace, Rich
zekesman
Post by zekesman on Mar 2, 2017 16:04:53 GMT -5
Was using a SS step bezel. I think I pushed to hard. Guess I should play around with cheaper material first to build my skills. The crazy setting will look better with a shallow jasper anyway! It may be easier to start with some ovals. Sharp points can be hard. I would recut it round the ends and try again. Vic
Post by Fossilman on Mar 3, 2017 16:25:32 GMT -5
Again,beautiful setting and stone!! Outstanding craftsmanship..
Post by melhill1659 on Mar 3, 2017 19:45:53 GMT -5
Was using a SS step bezel. I think I pushed to hard. Guess I should play around with cheaper material first to build my skills. The crazy setting will look better with a shallow jasper anyway! It may be easier to start with some ovals. Sharp points can be hard. I would recut it round the ends and try again. Vic Great Idea Vic. That's what I'll do. Fossilman Thank You I will use the setting when I find the stone that whispers to me to be placed in it. I am going to reshape the Rhodochrosite.
Post by melhill1659 on Mar 3, 2017 23:06:47 GMT -5
Might help to file ss corners down a bit. Less pressure. That's a nice design and lovely rhodochrosite. Thank you
