santabarbara
Member since February 2017
Post by santabarbara on Mar 19, 2017 18:57:52 GMT -5
Hi Everyone,
My cab machine has the original rubber rectangle sheets hanging down to spread the water across the wheels, unfortunately they dont work very well and the water is usually sent to one side or another. For all you crabbers and lapidarists, what do you use to spread the water across the wheels, or drums? What works best?
Thanks!
santabarbara
Post by santabarbara on Mar 20, 2017 18:19:50 GMT -5
anyone?
Post by Pat on Mar 20, 2017 18:22:11 GMT -5
I don't know. My Genie doesn't have those. Hope someone knowledgeable sees this.
Good luck.
Welcome!
Post by Bluesky78987 on Mar 20, 2017 19:17:25 GMT -5
My cabking has two little nozzles (from a splitter) on the aquarium hose above each wheel. Would probably be pretty easy to set up even if that's not the original layout. Y Splitter linkIndividual nozzleCabking seems to sell them, but you can probably get them cheaper elsewhere.
zarguy
Member since December 2005
Post by zarguy on Mar 20, 2017 19:30:16 GMT -5
I buy old Karate belts at the thrift store, glue them into a 3-sided form to spread the water on the wheel & catch spray from the sides. For 3" wide drums, I use 2 widths in the center, one on each side. I use green contact cement for permanence, but attach them to the hood with temporary rubber cement. I'm sure I've posted a picture here somewhere. Yes, somewhere. Lynn
sphereguy
Hello all I've been lurking for months now
Member since March 2017
Post by sphereguy on Mar 20, 2017 21:03:44 GMT -5
So your saying your machine has a black belt. Better not mess with it it's a lethal weapon. Hehe.
zarguy
Post by zarguy on Mar 20, 2017 21:37:22 GMT -5
White belt, but it eats agates! Lynn
Post by johnjsgems on Mar 23, 2017 12:28:58 GMT -5
I've seen everything from old inner tubes, carpet, green scrubbies, and what I use, the vinyl strips they hang in freezer doors in restaurants. I install the strips with screws and washers so they can be easily replaced.
Post by jakesrocks on Mar 23, 2017 15:58:39 GMT -5
If there's a leather shop near you, heavy oil tanned saddle leather works good. I've also seen sections of old fire hose used, as well as the heavy belting used on antique tractors. Cheap kitchen sponges will also work.
santabarbara
Post by santabarbara on Mar 24, 2017 20:02:30 GMT -5
thanks everyone!
Post by Rockoonz on Mar 24, 2017 23:53:59 GMT -5
I use the green generic scotch brite type scrubbies, they seem to work best for me.
Post by Tommy on Mar 26, 2017 18:16:47 GMT -5
I use the green generic scotch brite type scrubbies, they seem to work best for me. That's what I'm currently using too. It was Was thin carpet before that. santabarbara - welcome to the board. All you really need is any material that will knock the water down on the wheel and keep centrifugal force from sending it in your direction.
