ivy462
Member since April 2017
Post by ivy462 on Apr 10, 2017 9:52:10 GMT -5
I want to use my Dremel to cut Square out of a piece of stone. I just got a Dremel yesterday so I know very little about it and I was wondering if anybody knew if it's possible to cut a square out of a piece of stone with a Dremel saw blade thank you for your help in advance
Post by Tommy on Apr 10, 2017 10:36:42 GMT -5
Hi ivy462 welcome to the forum. Yes your post is in the perfect spot. I haven't done what you are describing but the dremel sounds like the right tool for at least part of the process. How deep/wide is the hole you want to cut - and how thick is the rock? Is it a cut slab of rock or just a rough rock? Maybe if you can describe your project in a little more detail it will give us a good starting point.
