Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Apr 12, 2017 12:44:43 GMT -5
Labradorite and Pearls. This one isn't quite perfect but I'm glad I followed through with finishing it anyway. Labradorite ring, brushed finish. Brushed finishes are sooooooo easy! LOL Royston turquoise ring, brushed finish.
Post by rockjunquie on Apr 12, 2017 13:55:33 GMT -5
Beautiful! I love the brushed finishes and no fingerprints.
Post by toiv0 on Apr 12, 2017 14:04:27 GMT -5
Again elegant and substantial at the same time. On the pendants with the curved wire, what guage is the wire?
Post by Pat on Apr 12, 2017 14:16:26 GMT -5
Pearls are perfect with the labradorite! Everything else would be less. Beautiful work.
Don
Post by Don on Apr 12, 2017 14:29:14 GMT -5
Again elegant and substantial at the same time. On the pendants with the curved wire, what guage is the wire? I think it was 12ga
Don
Post by Don on Apr 12, 2017 14:30:43 GMT -5
Pearls are perfect with the labradorite! Everything else would be less. Beautiful work. I was originally planning on using white moonstones, but I didn't have any on hand, so I split a 5mm pearl in half. They look great with the labradorite.
Post by Pat on Apr 12, 2017 14:33:41 GMT -5
Pearls better than moonstone. Moonstone would be almost more of the same. Pearls less so.
Don
Post by Don on Apr 12, 2017 15:55:04 GMT -5
Pearls better than moonstone. Moonstone would be almost more of the same. Pearls less so. agree completely, the pearls are a perfect match with labradorite.
bsky4463
Member since September 2013
Post by bsky4463 on Apr 12, 2017 15:59:45 GMT -5
I like them all..Alot going on in that pendant, I bet it was a challenge to align and assemble. Love the capture on the last ring. Cheers
Post by pghram on Apr 12, 2017 18:13:33 GMT -5
The only thing better than your workmanship are your designs.
Peace, Rich
jet
Member since April 2017
Post by jet on Apr 12, 2017 19:15:35 GMT -5
Wow, that is gorgeous workmanship.
Post by melhill1659 on Apr 12, 2017 19:21:12 GMT -5
Breathtaking!
Post by Tommy on Apr 12, 2017 19:21:59 GMT -5
Wow Don - spectacular work.
Post by MrP on Apr 12, 2017 19:28:24 GMT -5
Great workmanship!.............................................MrP
icatz
Member since October 2015
Post by icatz on Apr 13, 2017 8:59:54 GMT -5
Beautiful. That lab ring is stunning. I did the brushed finish on a copper ring and it's fantastic! I did mine by sanding, is that how you did yours?
Post by melhill1659 on Apr 13, 2017 9:29:18 GMT -5
Again elegant and substantial at the same time. On the pendants with the curved wire, what guage is the wire? I think it was 12ga Don, Do you have any tips on cabbing the Lab? I have a small beautiful piece an I'm a little skittish about cabbing because everything I've read says it's very Heat sensitive and fragile.
Post by Bluesky78987 on Apr 13, 2017 9:30:50 GMT -5
Love the workmanship and designs on those! Saved a couple of them to Pinterest, hope that's ok!
Post by Garage Rocker on Apr 13, 2017 9:36:45 GMT -5
Beautiful work! I love that Labradorite ring.
zekesman
Member since May 2016
Post by zekesman on Apr 13, 2017 11:20:31 GMT -5
Stunning designs and top notch craftmanship. Vic
Don
Post by Don on Apr 13, 2017 12:37:51 GMT -5
Don, Do you have any tips on cabbing the Lab? I have a small beautiful piece an I'm a little skittish about cabbing because everything I've read says it's very Heat sensitive and fragile. It's not bad, just go slow and keep the stone wet.
