Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on May 9, 2017 16:43:33 GMT -5
So ... with all the talk about another polish method I have decided to run Dual Barrels using the same type of rocks and using the 2 different polish methods. I am using a Lortone QT66 dual six pound tumbler. Loaded each barrel equally with the same type of rocks, mostly Quartz along with some glass, chert and flint. These rocks have already completed Stage 1 rounding and are ready to head on to the polish stage. One barrel will go for the Normal 3 remaining steps of polish rolling for a week in each, 120 - 600 - Cerum Oxide polish. The other barrel will spin with Aluminum Oxide AO80 for 10 days then a week of CO polish. This was started 2 days ago on Sunday. I had a friend here when I was getting all this going and he was distracting me quite a bit. Normally I would run a cleaning stage after Stage 1 to make sure no Course Grit could contaminate the experiment, but I was distracted by my friend, plus he was pushing me to be in a hurry, and I forgot to wash the stones, but I will continue the experiment as planned and thoroughly wash the stones before the next stages.
Post by wigglinrocks on May 9, 2017 17:13:08 GMT -5
Good way to see if this way is better than that way .
notjustone
Member since January 2017
Post by notjustone on May 9, 2017 22:37:46 GMT -5
So ... with all the talk about another polish method I have decided to run Dual Barrels using the same type of rocks and using the 2 different polish methods. I am using a Lortone QT66 dual six pound tumbler. Loaded each barrel equally with the same type of rocks, mostly Quartz along with some glass, chert and flint. These rocks have already completed Stage 1 rounding and are ready to head on to the polish stage. One barrel will go for the Normal 3 remaining steps of polish rolling for a week in each, 120 - 600 - Cerum Oxide polish. The other barrel will spin with Aluminum Oxide AO80 for 10 days then a week of CO polish. This was started 2 days ago on Sunday. I had a friend here when I was getting all this going and he was distracting me quite a bit. Normally I would run a cleaning stage after Stage 1 to make sure no Course Grit could contaminate the experiment, but I was distracted by my friend, plus he was pushing me to be in a hurry, and I forgot to wash the stones, but I will continue the experiment as planned and thoroughly wash the stones before the next stages. why not run the ao 80 for the same 14 days as your 120 and 600 stage? you know apples to apples to see if ao-80 breaks down to the same prepolish.
napoleonrags
Member since October 2015
Post by napoleonrags on May 10, 2017 20:15:21 GMT -5
Awesome. Mad scientist Rock here. Aprentice to jamesp. You might get sucked into the vortex that you're circling here. Be careful, and gather no moss. Colin
Post by jamesp on May 10, 2017 20:23:16 GMT -5
14 days is a good idea for the AO 80.
notjustone
Post by notjustone on May 10, 2017 23:03:30 GMT -5
I don't think the ao-80 is a time saver as much as cutting out the need to stock an extra grit.
Post by jamesp on May 11, 2017 4:23:16 GMT -5
I no longer stock 220-500-1000 notjustone. Gave it all away. Just SiC 30, AO 80 and AO 14,000. Best part is saving time and hassle in 220-500-1000 clean outs. Roll 6 barrels at times. Allows skipping 12 clean outs. Not going back to all those clean outs. Still have a 10 pound box of SiC 500, it's yours if you want it.
notjustone
Post by notjustone on May 11, 2017 7:03:59 GMT -5
I no longer stock 220-500-1000 notjustone . Gave it all away. Just SiC 30, AO 80 and AO 14,000. Best part is saving time and hassle in 220-500-1000 clean outs. Roll 6 barrels at times. Allows skipping 12 clean outs. Not going back to all those clean outs. Still have a 10 pound box of SiC 500, it's yours if you want it. I'm getting just as good results with the unscreened in the homemade rotary, ao-80, to ao polish in the vibe as I did with the 4 step process (actually 5 cause I was running sic30, then into the 2 hf units using the grit stages I bought as a kit. 60/90, 150/220, 500, ao polish). the only difference is I'm not running all mohs 7 stuff. the hardest stuff comes out great. 85 to 90 percent of the load on average comes out of polish looking finished. the other 10 to 15 percent Ive been setting aside till I get enough to fill my ar-12 barrel. mostly slag glass which I found polishes better in the rotary than the vibe, but unfortunately is about the only thing I find locally which is even hard enough to take a polish. thanks for the offer james but I don't really need the sic 500. like you I'm cutting out the excessive cleanouts. I'm not sure if my unscreened sic is cutting faster or not than the 30 grit (never loaded a barrel with each with new rough to do a head to head compairison). but its free grit and seems to be working well. when I went from the sic 30ish stuff to the unscreened I also went to the vibe and using more broken rough and doing less rounding and more just passing it through when the edges were knocked off and pit free for a different look. at the same time I added 2 more coarse barrels and am pulling 10 lbs out of coarse a week compared to the 3lbs I was sending through to the small rotaries. I changed to many variables at once to get a good comparison.
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on May 11, 2017 7:24:43 GMT -5
I went ahead and purchased a 3rd barrel for the QT66 tumbler to be used for polish. So I'll probably stick to my 10 day plan for the AO 80 Tumble so the polish barrel isn't needed twice at the same time.
Post by HankRocks on May 11, 2017 7:26:19 GMT -5
I have successfully transitioned to a slightly different 3 step tumbling process; 1) Rotary- 46/70 SiC with recharges every 2 days for as long as it takes, 2) Rotary - 220 SiC with a re-charge at about 2 days, then 10 to 11 days, 3) Vib - 14,000 AO for about 72 hours.
There is a Ivory soap & Borax run at the end of the 220 and the polish stages. I also extend the from 2 to 3 days for the 220 recharge if I am running preforms with lots of pea gravel added. Will also use 80 SiC instead of 46/70 for the Preforms. Every time I think about dropping the after 220 soap run, the gray color after the soap run convinces me it's washing out some very fine SiC.
Run this for about 4 or 5 months and everything coming out with a very nice polish.
Still using the 600 SiC for the Vib Lap, so the selection of grit sizes has not decreased.
Henry
Post by jamesp on May 11, 2017 7:36:26 GMT -5
I no longer stock 220-500-1000 notjustone . Gave it all away. Just SiC 30, AO 80 and AO 14,000. Best part is saving time and hassle in 220-500-1000 clean outs. Roll 6 barrels at times. Allows skipping 12 clean outs. Not going back to all those clean outs. Still have a 10 pound box of SiC 500, it's yours if you want it. I'm getting just as good results with the unscreened in the homemade rotary, ao-80, to ao polish in the vibe as I did with the 4 step process. the only difference is I'm not running all mohs 7 stuff. the hardest stuff comes out great. 85 to 90 percent of the load on average comes out of polish looking finished. the other 10 to 15 percent Ive been setting aside till I get enough to fill my ar-12 barrel. mostly slag glass which I found polishes better in the rotary than the vibe, but unfortunately is about the only thing I find locally which is even hard enough to take a polish. thanks for the offer james but I don't really need the sic 500. like you I'm cutting out the excessive cleanouts. I'm not sure if my unscreened sic is cutting faster or not than the 30 grit (never loaded a barrel with each with new rough to do a head to head compairison). but its free grit and seems to be working well. when I went from the sic 30ish stuff to the unscreened I also went to the vibe and using more broken rough and doing less rounding and more just passing it through when the edges were knocked off and pit free for a different look. at the same time I added 2 more coarse barrels and am pulling 10 lbs out of coarse a week compared to the 3lbs I was sending through to polish to the small rotaries. I changed to many variables at once to get a good comparison. The unscreened SiC is real interesting. A grit salesman gave me SiC 8 and Sic 16. It is not much different than SiC 30. Breaks down due to SiC's brittle behavior. I think you could put 1/2" chunks of SiC in a tumbler and it would simply break down and shape your rocks. Think your unscreened SiC with +/- 30 grit particles is perfect since it can probably be had way cheaper. Screening takes a lot of effort. Yes, you get it for free. But us civilians can probably buy it way cheaper than screened. do the same darn job. Probably only available in bulk. Hell, I have purchased over a dozen 50 pound lots of coarse SIC. Bet a 2000 pound palet of unscreened is cheaper. Bet ya. Always was curious if there was bulk SiC for cheap. Your tumblers will process it. Never tried AO 80 on softer stuff. Probably not a good idea. Soft does best with 80-220-500-1000-14,000. But I gave up on soft. No telling how many runs AO 80 at this point(on Mohs 7). It has just become a routine, no variables. Predictable/repeatable blah blah.(wish I knew then what I know now...)
notjustone
Post by notjustone on May 11, 2017 9:01:47 GMT -5
the unscreened sic is just that crushed and unscreened. some chunks are much larger than 30 grit some much smaller. think of it like this take a boulder and crush it your gonna end up with big chunks med chunks small chunks super small right down to dust. now set up a series of screens oversize, usually oversized would be sent back through the crusher or say to a smaller crusher if your goal is more smaller sized rocks. say 4 inch holes in screen. next is 2 inch holes then 1 inch on down in size to basically dust. the size of actual grain in that boulder isn't what your sorting its the size of the nugget. put sic under microscope and lets just use random numbers say a sic 30 fits through a certain size hole in a screen and has 100 grains. now lets say 500 grit is a much smaller nugget only containing 10 grains. get what I'm saying? whats more interesting is the big chunks are still there after a week of grinding there are still chunks wayyy bigger than 30 grit still cutting. think time release like your doing with your broken up grinding wheels. now heres where It gets trippy and this is all theoretical at this point. don't sort it out and you have fine stuff in there that is taking the deep scratches out while it wont polish because the whole time your getting big scratches from the bigger stuff. your getting a big scratch plus a bunch of little ones. is it cutting faster or slower? is it going to be rougher or smoother? the only way to tell is to do head to head experiments. looking in bucket as is swept and shoveled right up off the floor. I just grabbed a handful and let my fingers sort out some of the bigger stuff. pm me your addy james and ill just send you 10 lbs or so to try. you like experimenting so you can try a head to head.
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on May 11, 2017 17:53:42 GMT -5
I did my barrel flipping this morning and found it interesting that they sounded very different from each other.
Post by jamesp on May 11, 2017 18:56:07 GMT -5
the unscreened sic is just that crushed and unscreened. some chunks are much larger than 30 grit some much smaller. think of it like this take a boulder and crush it your gonna end up with big chunks med chunks small chunks super small right down to dust. now set up a series of screens oversize, usually oversized would be sent back through the crusher or say to a smaller crusher if your goal is more smaller sized rocks. say 4 inch holes in screen. next is 2 inch holes then 1 inch on down in size to basically dust. the size of actual grain in that boulder isn't what your sorting its the size of the nugget. put sic under microscope and lets just use random numbers say a sic 30 fits through a certain size hole in a screen and has 100 grains. now lets say 500 grit is a much smaller nugget only containing 10 grains. get what I'm saying? whats more interesting is the big chunks are still there after a week of grinding there are still chunks wayyy bigger than 30 grit still cutting. think time release like your doing with your broken up grinding wheels. now heres where It gets trippy and this is all theoretical at this point. don't sort it out and you have fine stuff in there that is taking the deep scratches out while it wont polish because the whole time your getting big scratches from the bigger stuff. your getting a big scratch plus a bunch of little ones. is it cutting faster or slower? is it going to be rougher or smoother? the only way to tell is to do head to head experiments. looking in bucket as is swept and shoveled right up off the floor. I just grabbed a handful and let my fingers sort out some of the bigger stuff. pm me your addy james and ill just send you 10 lbs or so to try. you like experimenting so you can try a head to head. That looks like the way to go. I'd tumble with that in a heart beat. Betcha it can be had for 20 cents a pound. They are in fused clods. The important part is the size of the grains. Hopefully the grains are 30-50 grit. it's going to have dust and small grains. Probably is around 10-50 grit. Has to be crushed and screened to be graded to different sizes to be called graded. Should grind your rocks just fine. I have been tumbling for years with 30 grit and grinding wheels. I can tell you how effective it is. I'll PM and give it a go. thanks a bunch.
notjustone
Post by notjustone on May 11, 2017 23:23:07 GMT -5
I thought about screening out the really fine stuff. but just said the heck with it. it will just help make slurry faster lol. I'm scooping right out of pail about 1 cup for 10 lbs rock and dumping it in. probably to much cause at the end of a week there is still a lot not broken down. I stand my barrel up for a few minutes let the slurry settle pour off half the watery slurry. then dump my rocks into a colander with a bowl below it shake the colander a few times to knock some more grit filled slurry off. this goes back in next batch. then I rinse the rocks off in colander. I know I'm losing a lot here and bet if I built a simple cleanout sink with a couple 5 gal settling tanks ide find I'm losing a ton of unspent grit. I just haven't set anything up yet. there will still be chunks in there after a week that wont fall through a kitchen colander. I pull all my stones down to about 1/2 inch the small stones and chunks of grit to big to go through colander go back into the next batch.
notjustone
Post by notjustone on May 11, 2017 23:26:22 GMT -5
I did my barrel flipping this morning and found it interesting that they sounded very different from each other. different as in? btw sorry about hijacking your thread.
Post by jamesp on May 12, 2017 7:12:53 GMT -5
I thought about screening out the really fine stuff. but just said the heck with it. it will just help make slurry faster lol. I'm scooping right out of pail about 1 cup for 10 lbs rock and dumping it in. probably to much cause at the end of a week there is still a lot not broken down. I stand my barrel up for a few minutes let the slurry settle pour off half the watery slurry. then dump my rocks into a colander with a bowl below it shake the colander a few times to knock some more grit filled slurry off. this goes back in next batch. then I rinse the rocks off in colander. I know I'm losing a lot here and bet if I built a simple cleanout sink with a couple 5 gal settling tanks ide find I'm losing a ton of unspent grit. I just haven't set anything up yet. there will still be chunks in there after a week that wont fall through a kitchen colander. I pull all my stones down to about 1/2 inch the small stones and chunks of grit to big to go through colander go back into the next batch. When I break up grinding wheels into smaller pieces I get all kinds of powder, chunks, dust, 50 grit particles. I am not particular. The whole mess gets swept into a container and it all gets chunked in the rotary. It looks just like the mess you are getting from your work place. Rotary tumble will process it all. They are not particular. The mix grinds rocks just fine. Your resource could save a bunch of money for rock tumblers. I don't do full clean outs when running chunks of grinding wheels. I pour water into the barrel sitting vertical and dump it about 3 times till slurry is thinner. Then add more caused SiC chunks. I do not dump the rocks out. That way the unused grit and chunks settles to the bottom and stays in the grind cycle. Some of the larger chunks last 3 weeks. 220-500-1000 or the AO 80 method steps uses little grit. It is the coarse grind SiC that cost so much money and time in tumbling. I am 5-12 weeks coarse grinding with 10 cups grit. finish is tablespoons and 3-4 days in the vibe. 4 days verses 2 months...10 cups SiC 30 verses 2-10 tablespoons finishing grits.
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on May 12, 2017 8:34:42 GMT -5
I did my barrel flipping this morning and found it interesting that they sounded very different from each other. different as in? btw sorry about hijacking your thread. Since you asked I decided to go out for a good listen and pop them open and get a look at what's going on . . . These 6 pound barrels have been rolling for 5 days now. The AO barrel originally got a Cup of AO-80 and right now it sounds like it's rolling in Plain water. It is much louder with glassy high frequency sounds. The AO-80 was not like grit at all and much more like a powder now. The Quartz I checked was extremely smooth but didn't shine when cleaned and dry. Planning to run this barrel for 5 more days before going to CO polish. The SiC 220 barrel got a little more than 1/2 a cup. It sounded much more normal and subdued a lot like my Stage 1 Tumbles without the glassy sound. The 220 grit was not detectable at all on the rocks or settled to the bottom, so I recharged with 1/4 cup more while I was in there. I did not look at the stones because I know they will be dull and lifeless in this grit. Planning to run this barrel 2 more days and cleanout to 600 grit for another week.
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on May 14, 2017 12:44:50 GMT -5
Cleanout day for the normal 4 Stage Barrel. The 220 SiC was not detectable at all, just dirty water. Washed the rocks for an hour in plain water, added some plastic beads and half a cup of SiC 600, now rolling for another week. I've been tumbling in rotaries for 5 months now and have never had a problem with Gassing, but I had to burp the barrel 3 times during the week I was running the 220 SiC stage. The barrel almost came open the first time because I wasn't really looking for this problem. I opened the AO-80 barrel just to see what's going on in there. The AO was settled to the bottom and was a very fine powder. Washed a few samples off and let them dry to see the finish, I thought they looked exactly like the the samples from the SiC 220 barrel. There was not any gassing in this barrel at all. Did not make any changes and put the lid back on to roll for 3 or 4 more days. Here is a picture of that barrel and the samples I looked at.
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on May 17, 2017 20:09:46 GMT -5
Wednesday Update The AO-80 barrel has been running for 10 days and I have moved everything on to the Polish in the new barrel. Started with a heaping cup of AO-80 and it was almost totally broken down into a milky liquid. Did 2 plain water cleanings for about 30 minutes each, One cleaning in the Course barrel and the 2nd cleaning in the New Polish barrel. Used 2/3 rocks and 1/3 new plastic beads and filled barrel to 80% rocks and water, added 3 Tablespoons CO Cerium Oxide polish and let her spin. Here is a picture of the rocks all together and a couple of the samples that interest me the most. Not shiny yet but a nice glossy sheen. Recharged the 4-step barrel, Added 1/4 cup SiC 600, did not inspect it. Will move on to polish when the AO barrel is finished a week from now on Wednesday. This roach came out of the 600 grit when I recharged the barrel. Kinda surprised me at first.
