Post by opalpyrexia on May 10, 2017 16:12:09 GMT -5
This is the first time that I've worked with ammolite. After I finished cutting the cab, I coated its slightly concave surface with 330 epoxy and all was good. It sat for a few months before I decided to create a pendant. I opted for an epoxy set because of its vertical edges, so I figured that it would make sense remove the existing epoxy layer and do both the setting and new top coat in one operation. That didn't work out well. There were some fibers on the ammolite or between the "scales" that I couldn't see. I couldn't even see them after the epoxy was smooth and still fluid. But at some point during the curing process they eventually managed to float to the surface. Crap! So now I had to remove the top layer of the epoxy and do it over. That seemed to work well but for some unknown reason, the surface was hazy as if it had been finely abraded. What to do?! I decided to try to restore the polished surface by taking a small amount of 50k diamond paste and working it around the surface with my finger. It worked really well and didn't take all that long. The bezel is 20 gauge that is slightly higher than the ammolite for protection. The other stone is a 5 mm garnet.
metalsmith
Post by metalsmith on May 10, 2017 17:05:00 GMT -5
Sterling work! (pun intended)
Post by opalpyrexia on May 10, 2017 17:28:32 GMT -5
Thank you, metalsmith. I appreciate your in de pendant opinion.
Post by pghram on May 10, 2017 18:05:43 GMT -5
Stunning!
Peace, Rich
gemfeller
Member since June 2011
Post by gemfeller on May 10, 2017 19:20:31 GMT -5
Very nice - clean design and excellent concept/workmanship. Makes me want to get out the torch and go to work on several fine ammolites I have squirreled away. One of these days...
Post by Pat on May 10, 2017 19:22:11 GMT -5
Beautiful! Thanks!
Post by morerockspleaz on May 10, 2017 20:04:37 GMT -5
Wow that is unique. Great shine, perfectly complemented. Love it
Post by toiv0 on May 10, 2017 20:05:01 GMT -5
I like it when a plan comes together. Pretty sweet piece
icatz
Member since October 2015
Post by icatz on May 11, 2017 7:57:37 GMT -5
Great smithing there! Love the center bead. You wouldn't think it would hold it all together but it looks mighty tough. Great work!
Post by rockjunquie on May 11, 2017 8:25:04 GMT -5
Looks like it was worth all the effort. I love the bezel being a little higher- nice touch... and practical.
Gayle
Hi, born and raised in Arizona. Love rocks and fossils.
Member since May 2017
Post by Gayle on May 15, 2017 18:57:32 GMT -5
That is very nice.
Post by vegasjames on May 15, 2017 19:22:34 GMT -5
Ammolite? Must be a small caliber. Seriously, nice job.
takecouragedesigns
Rocks of Ages, cabbed for me!
Member since September 2010
Post by takecouragedesigns on May 19, 2017 8:21:11 GMT -5
Exquisite! The garnet complements the ammolite perfectly!
Erich
Member since November 2015
Post by Erich on May 19, 2017 10:57:47 GMT -5
Very attractive!
