Post by takecouragedesigns on May 18, 2017 12:45:19 GMT -5
I'm just venturing into smithing/soldering, after being a long time wire wrapper. I have this idea that I'm trying out with an Ed Orekar Montana Agate pendant. Trying to add a faceted smoky quartz gemstone accent, but it is already in a sterling setting. I know that for the most part, you can't solder with a stone already there, but is smoky quartz one that you could get away with that process? It's in a prong setting, so am reluctant to unmount it for the risk of ruining the prongs.
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on May 18, 2017 12:49:12 GMT -5
No, quartz is heat sensitive. You'll need to remove it first, or gamble with some kind of heat sink to protect the stone while soldering.
metalsmith
Post by metalsmith on May 18, 2017 14:09:12 GMT -5
No, quartz is heat sensitive. You'll need to remove it first, or gamble with some kind of heat sink to protect the stone while soldering. ^^That! I've tried and failed - feel free to try again.. bad science is keeping on doing the same thing and expecting different results. With an efficient heat sink you *may* get away with the heating, but then will you actually get the piece hot enough to allow your solder to run?
gemfeller
Member since June 2011
Post by gemfeller on May 18, 2017 19:20:45 GMT -5
You probably could do it with gold but silver's a different animal. It's one of the best heat conducting metals known and the whole piece must reach soldering temp before the solder flows. That'll cook most stones. There are a couple of advanced ways to do it with silver but one is risky and the other involves a special technique using an electric soldering machine that costs upwards of $500. It's always best to remove stones before soldering.
Post by takecouragedesigns on May 19, 2017 8:13:34 GMT -5
Thank you so much for your helpful responses- looks like I'll have to lift some prongs and remove a stone!
