bsky4463
Member since September 2013
Post by bsky4463 on Jun 19, 2017 11:55:26 GMT -5
My typical lubricant is petroleum based cutting oil. I would like to temporarily setup one of my saws using water and an additive as lubricant to cut some softer, more porous materials into slabs. All of my saws are in excellent working condition right now, and I do not want to jeopardize their long term functionality.
I am looking for advice from any of you slabbers out there who have specific experience with using water as a lubricant in vintage (in my case HP) auto-feed slab saws and any precautions one should take. Many thanks for your time. Cheers...
Post by Peruano on Jun 19, 2017 12:10:21 GMT -5
I use oil even in my 8" trim saw, but did try water with smokey joe's magic lube additive in a 10" HP saw only to find that it did not prevent rust and that the saw had to be cleaned/drained daily a deal breaker for me. I've always heard that water was not adequate for anything above a 10" blade. Temps may be to high, speeds to fast to allow it to adequate cool things before boiling away? Drain, mop, and dry. Perhaps a squirt of wd-40. Que mas?
bsky4463
Post by bsky4463 on Jun 19, 2017 13:10:42 GMT -5
Peruano thanks for the input, similar experience here..... I tried using water with an additive in my 10" and soon after had the bearings go out. Not sure it was related, but I suspect so - hence my apprehension. Thanks for your time. Cheers
Post by johnjsgems on Jun 19, 2017 14:52:21 GMT -5
I have a customer that uses oil for cutting agates/jaspers in his BD HP14. When he cuts Chrysacolla he drains oil, cleans saw, uses Smokey's EZ Cut to cool 10" blades I had bored to 1" for him. After, he drains, cleans, puts the 14" blade back on and refills with either new or filtered oil. My original 10" Frantom I used oil and stock piled anything that needed to be cut with water, When oil got mucky I drained and cleaned, filled with water and cut the stockpiled rock. Then drain, dried, refilled with oil.
panamark
Member since September 2012
Post by panamark on Jun 20, 2017 8:07:46 GMT -5
Andy, I think you got it right when you mentioned that the water got into the bearings and ruined them. I think the saws with the bearing inside the hood will all have this potential problem. I have a Harbor Freight brick saw www.harborfreight.com/10-in-25-hp-tilebrick-saw-69275.html (cheaper when on super sale!) that I use outside with water and RV antifreeze for hacking big stuff up and for carving off chunks of attached matrix. Works really fast/well, even if it is very wet.
bsky4463
Post by bsky4463 on Jun 20, 2017 8:43:17 GMT -5
Thanks johnjsgems, still leery of running the water....Thanks for input panamark hey Mark, been awhile....I am still cutting my pile of holiday Jasper (nice find). Ayup I think your right. Thanks for your input. Even better I think I will hit up a contractor friend and use his wet saw. Cheers
Post by Fossilman on Jun 20, 2017 9:29:21 GMT -5
Water scares me with machinery! Being a mechanic I have seen and worked on some terrible stuff,because of water damage! I also even use oil in my 6" trim saw.... Water can be evil to machinery,very evil!!
bsky4463
Post by bsky4463 on Jun 20, 2017 10:20:06 GMT -5
Water can be evil ....very evil!!
Post by Deleted on Jun 20, 2017 10:29:52 GMT -5
Cut is slower. Perhaps softer material will be accommodated.
Post by socalagatehound on Jun 20, 2017 11:58:40 GMT -5
In my big slab saw (20") I use mineral oil. For trimming, I use a 10" saw set up like a 6' trim saw, just bigger. I use a small amount of food quality mineral oil in water with a few drops of shampoo to dissolve the oil. Seems to work better on some blades than others. I use a Raytech yellow blazer blade for trimming. If I don't push rock through it, the blade seems to last a long time.
Craig
Post by Rockoonz on Jun 20, 2017 22:39:08 GMT -5
sphereguy was telling me he was setting up a dedicated water saw. Haven't got a report so far. My water trim saw is an old HP with the bearings completely separate from the saw body, it works fine. Of course I use an additive.
sphereguy
Hello all I've been lurking for months now
Member since March 2017
Post by sphereguy on Jun 21, 2017 1:15:22 GMT -5
I have three saws that I use only water on now. They all were oil saws but have been cleaned up and I use them only with tap water They are drained and the blades are dried after each use. So far I have noticed the small highland park trim saw 6 in with a brand new mk 301 blade seems to chip out a bit more using water vs. oil but it is a new blade, still a bit agressive. I very much enjoy the water vs the oil in cleanup of stones and hands. The other highland park 10 inch trim saws are water only and these are attached to arbors, one a b 12 and the other I think a b50 or 52 I like the water on these as there are no contamination of oil on the far left wheels. All of the other saws are inexpensive mineral oil.i have learned the hard way using oil on crysacolla so having a dedicated saw for cutting those petulicar stones that oil can taint is critical. Maybe I'll try water and an additive in the old j3 for those bigger more sensitive rocks. I will say that twenty plus years as a tile and granite guy has taught me to always keep blades dry after use. Rust happens quickly.
bsky4463
Post by bsky4463 on Jun 22, 2017 13:09:28 GMT -5
seems like an underlying theme for those that do use water is to: 1. Preferably use a saw where the bearing are separate from the saw body (cutting area) 2. Clean up and dry off everything after each session
thanks all for your input, cheers
QuailRiver
Post by QuailRiver on Jun 22, 2017 13:58:14 GMT -5
sphereguy was telling me he was setting up a dedicated water saw. Haven't got a report so far. My water trim saw is an old HP with the bearings completely separate from the saw body, it works fine. Of course I use an additive. IMO a dedicated saw for water only is a good idea. I have an old 12" Slik brand lapidary drop saw with a large tin reservoir tub which I use with tap water only. Bought it cheap off of Craig's list a few years ago. The saw was already old and rusty when I got it so it is no loss to use with water. I use water resistant grease in the saw's bearings and use the cheap Chinese crimped edge blades with it that I bought from HANS lapidary a few years ago (10 for $92.00). So the short lifecycle of using a 12" blade with water doesn't get too costly. Can't cut the harder materials with these crimped edge blades and water but I've managed to cut a lot of Picture Rock from the Uwharries, Palomino Picture Rock from Oregon, Howlite from Tick Canyon, Flowering Tube Onyx from Utah, and various copper minerals, etc. with them. After using this saw I empty the reservoir, hose everything but the motor down, and then wipe the whole thing down with a natural sponge and leave to air dry. When I'm done using it for a while, after it's dried, I spray it with WD-40 before I put it away. As the saying goes "She ain't much to look at" but she gets the job done. If I only have just a few pieces of material needing to be sawn with water then sometimes I use water with Raytech's Raycool treatment added in either my Rock Rascal model "J" (for smaller pieces) or my Raytech 10" saw. After sawing I immediately drain, clean and dry the saw and then let the saw further air-dry over night. Then the next day add mineral oil to the reservoir and run the saw to circulate the oil and make sure every thing get's coated with oil well before storing. Larry C.
Post by orrum on Jun 23, 2017 6:25:18 GMT -5
Hey Larry what is picture rock ftom Uhwarrie??? I live in NC and ride horses in the Uhwarrie mntns.
QuailRiver
Post by QuailRiver on Jun 23, 2017 13:56:16 GMT -5
Hey Larry what is picture rock ftom Uhwarrie??? I live in NC and ride horses in the Uhwarrie mntns. I believe it is a type of argillite. It has been found at several locations along the Uwharrie River and some of the contributory creeks to the Uwharrie River. Most of it has a MOH's hardness of 5 to 6. It can be cabbed but doesn't take a high polish. Although I did dig out some that was next to a quartz vein so was a little harder from absorbing more silica and did take a better than average polish for this material. When out hunting artifacts back in the 70s and early 80s we used to find it as float from east of Denton all the way up to NW Randolph County. Around 1980 we found a vein and got permission from the land overseer and were able to collect a good bit of it. We sold some from that location at shows back in the 80s as "Louetta Picture Rock". But the owner of the land that vein was on passed away and the land was sold off. Part was divided up into residential lots, a road was put through, and the rest was fenced off by a new owner. So we no longer had access. I've also heard that there used to be a large vein of it by a steel bridge on hwy 64 near Tabernacle that the owners would let mineral clubs do field trips at back in the 1960s. But they got tired of people leaving trash and not filling in their holes so stopped letting anyone dig. Then in the 70s, hwy 64 was widened and rerouted in some stretches and I think that site was lost to collecting altogether as a result. Here are a few examples that I collected, slabbed and cabbed, back in late 70s and early 80s. Larry C.
Post by orrum on Jun 23, 2017 16:34:00 GMT -5
Oh man Larry thar is awesomeness!!! I will have to keep a eye out and a ear open to this picture rock!!! LOL Wow Oregon and Idaho look out North Carolina is on a roll!#!
