Post by 1dave on Aug 8, 2017 15:10:50 GMT -5
krazydiamond asked:
Hey all, anybody have any tricks or tips for cutting Amazonite? I am trying to make some mini-slabbettes and the stuff is just crumbling....? thanks.
Read more: forum.rocktumblinghobby.com/thread/new/22#ixzz4pCEGNYvi
here is some info from the RockShed:
therockshed.com/hardnessscale.html
I assume this holds true in other forms of working and finishing stones.
Helpful Hardness Tips
It is generally beneficial to tumble rocks of the same kind or of the same hardness together. Jaspers, Agates and Quartzes all have a hardness of approximately 7 to 7 1/2 and thus can be tumbled together. Rocks in this hardness range will be easiest for beginners.
Amazonite, Labradorite and Unakite are all in the Feldspar family at a hardness of approximately 5 1/2 to 6 and can be tumbled together. It is recommended that when tumbling stones of this hardness that an extra step of 1000 Grit Aluminum Oxide be run before the polish stage for 2 to 3 days.
Apatite, Fluorite, Malachite, Turquoise, Petosky stones and others are at hardness's of 4 to 5 and in some cases will need special techniques to polish such as polishing dry in Corn Cob.
Stones with hardness's of under 4 may not polish at all or will only take a light shine. It should be noted that some stones have certain textures, grains or combinations of hardness's which will make it challenging to get a high polish. Jade is a good example of this.
Rocks with hardness's of 9 or above are very difficult to tumble. Rubies and Sapphires fall into this category and are not a good choice for beginners as they will likely frustrate you and turn you off of tumbling all together.
