Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Aug 11, 2017 16:49:08 GMT -5
I have some condors, agua nueva, laguna and sierra madre agate nodules. is it better to cut these like a hot dog bun, or a loaf of bread? (can you tell I'm hungry? LOL)
Post by captbob on Aug 11, 2017 16:54:12 GMT -5
Post by Sabre52 on Aug 11, 2017 23:00:54 GMT -5
I'm a terrible person to ask this question because on that type nodule I pretty much let how I can get them firmly into the vice determine how I cut them *L*. That being said, those varieties of agate often have surface indications that tell you how to slice them for the best full patterns and I let that guide me too. Generally that winds up being perpendicular to the flat bottom if they have a flattish bottom. Condors are often very angular or fractured so you have to take that into consideration and of course, a lot depends on whether you want two even halves to polish or the most cabbing slabs you can get....Mel
Post by stardiamond on Aug 14, 2017 18:06:23 GMT -5
It depends on how big the piece is the shape and how visible the pattern is . I have a big problem with the vise so the first thing I do is make a cut so that I have a flat surface to glue to a board. Based on the first cut, I decide if I like the orientation. I prefer to get rough where I can see the pattern. Montana is tough to see inside, so I guess before the first cut. I like to buy rough that is faced or clearly shows the pattern. Bruneau can be cut in a lot of directions based on what is visible and then change the orientation based on the first cut when more is exposed.
