smittys
Member since August 2017
Post by smittys on Aug 17, 2017 11:54:28 GMT -5
Post by orrum on Aug 17, 2017 13:28:18 GMT -5
Oh I hate that happening. I also strongly dislike the sound of s cab demounting itself and flying off to hit the block wall...
Post by rockjunquie on Aug 17, 2017 14:02:23 GMT -5
Dude- I feel your pain!!! On the bright side, your polish looks good. Better to break now than in a piece of jewelry. Helpful tip- You do not have to push hard to get the diamonds to cut. In fact, they will cut better with less pressure.
Post by Fossilman on Aug 17, 2017 14:19:13 GMT -5
So many times too...Seems like jasper's like to do that often...
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Aug 17, 2017 14:32:03 GMT -5
A little bit of superglue and all is good. There is something that is just wrong with that happening.
Post by Deleted on Aug 17, 2017 14:58:20 GMT -5
Not always pressure that does that. Millions of tiny polish particles making billions of cuts each produce a tiny bit of heat. I have had balls come out of polish so hot I could not hold them in my hands.
Be careful!
Post by pghram on Aug 18, 2017 15:43:59 GMT -5
Too bad, it had great colors and shine.
Peace, Rich
Post by fantastic5 on Aug 18, 2017 20:27:21 GMT -5
Not always pressure that does that. Millions of tiny polish particles making billions of cuts each produce a tiny bit of heat. I have had balls come out of polish so hot I could not hold them in my hands. Be careful! Would this be Great Balls of a Fire?
Post by fantastic5 on Aug 18, 2017 20:28:17 GMT -5
That's heartbreaking smittys! Sure was looking fabulous up to that point though.
peachfront
Member since August 2010
Post by peachfront on Aug 18, 2017 20:44:08 GMT -5
I'm a little rough with mine because I would rather they break sooner than later... Look at them dry before you cut and note any cracks/possible weaknesses & later see if they are stand up. If they don't stand up, if they do crack, you will have learned more about what it looks like in the rough when a stone might have a fragile place. With practice, you will get an eye for "healed fractures" that are not really healed. It takes practice though. Everybody goes through that of cutting something almost allll the way & it breaks in polish, I think it's because polish can be such a "hot" stage.
Post by Rockoonz on Aug 19, 2017 10:46:22 GMT -5
Not always pressure that does that. Millions of tiny polish particles making billions of cuts each produce a tiny bit of heat. I have had balls come out of polish so hot I could not hold them in my hands. Be careful! Would this be Great Balls of a Fire? Goodness gracious!
