georgeb138
Member since April 2017
Post by georgeb138 on Aug 28, 2017 18:08:09 GMT -5
Pretty happy with this batch! Lots of ceramic is a must!
Post by gmitch067 on Aug 29, 2017 10:08:22 GMT -5
They look GREAT George.
What did you use for the polish stage? What size tumbler did you use?
I have some Apache Tears, and some larger pieces of Mahogany Obsidian that I have slated for a future tumble. Would they be OK to tumble together, or would the larger Obsidian destroy the Apache Tears?
Post by fernwood on Aug 29, 2017 12:24:15 GMT -5
Beautiful. I love Tears.
georgeb138
Post by georgeb138 on Aug 29, 2017 17:40:08 GMT -5
They look GREAT George. What did you use for the polish stage? What size tumbler did you use? I have some Apache Tears, and some larger pieces of Mahogany Obsidian that I have slated for a future tumble. Would they be OK to tumble together, or would the larger Obsidian destroy the Apache Tears? Since they are bothe technically obsidian I would think they would be fine to tumble together, but check your hardness levels and use a TON OF CERAMIC. These were 2 lbs in a 2 lb barrel. They practically filled the barrel, and then I added a lot of very small ceramic. Used AO for the polish stage, 2 weeks of prepolish one week polish. Burnish for 12-24 hours between stages. Didn't even change the ceramic. This was my first time with apache tears. But I got some great advice on a Facebook group. I have some mahogany obsidian as well. It has been..... troublesome. I got a decent luster to it, but can't get that deep shine that makes it look wet. Like it did when it was raw(in hand). Sigh
georgeb138
Post by georgeb138 on Aug 29, 2017 18:29:15 GMT -5
They look GREAT George. What did you use for the polish stage? What size tumbler did you use? I have some Apache Tears, and some larger pieces of Mahogany Obsidian that I have slated for a future tumble. Would they be OK to tumble together, or would the larger Obsidian destroy the Apache Tears? I think I would suggest getting the mahogany rounded before mixing the 2
Post by gmitch067 on Aug 29, 2017 18:39:39 GMT -5
Thank you Georgeb. I see what you mean with the Mahogany Obsidian. The piece in your hand took a really nice shine. I think I will tumble a load of Mahogany Obsidian first to knock off the edges (reduce them in size and define them more) before combining them with the Apache Tears. I also have a lot of 2mm ceramic beads for cushioning.
