Post by Fossilman on Aug 31, 2017 10:24:45 GMT -5
A shout out to you all that stabilize your rocks and or cabs before working on them.........What's your recipe choices and why?? Need to buy a supply and want to do it right the 1st go around... I have done repair work with glue,but never have had to stabilize rocks yet (And I should have-LOL).. Thanks all.........
Post by Fossilman on Aug 31, 2017 14:46:06 GMT -5
Jump on board anytime people.. Roy,what's that stuff called you use?? That's what I really want to use...
Post by Pat on Aug 31, 2017 15:33:11 GMT -5
I took an intarsia class recently. Teacher uses HOT STUFF Orange to stabilize/ fill tiny holes. Let it dry, then proceed as usual.
Kingsley North and Amazon carry it.
Post by Fossilman on Aug 31, 2017 15:35:25 GMT -5
I took an intarsia class recently. Teacher uses HOT STUFF Orange to stabilize/ fill tiny holes. Let it dry, then proceed as usual. Kingsley North and Amazon carry it. Awesome,thanks Pat!
Post by oregon on Aug 31, 2017 15:46:45 GMT -5
zarguy
Member since December 2005
Post by zarguy on Aug 31, 2017 16:51:57 GMT -5
Post by Fossilman on Aug 31, 2017 16:53:58 GMT -5
Thanks all,getting me on the right track now....
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Aug 31, 2017 17:29:41 GMT -5
Cactus juice in a vacuum chamber. This stabilizes soft materials that otherwise cannot be cut. materials have to be very clean and dry. Best to cook the rocks at a low temp for a few hours to reduce moisture content. also, should be slabs or small rough for best penetration. If you're looking to fill fractures and pits, hxtal is the way to go.
Post by Fossilman on Aug 31, 2017 21:25:28 GMT -5
I was thinking of trying "Opticon".... I think that's what Roy uses..
Post by Bluesky78987 on Sept 1, 2017 9:23:39 GMT -5
Yeah, a lot of people use opticon. It depends on how elaborate you want to get. I've avoided vacuum chambers and heating and all that - so the Opticon sits on the shelf. I've only used Hot Stuff before and it had soso results. I don't usually try to save fractured stones though - just have delicate or brittle stones - so I back those with other stones or with steel epoxy (or I've heard of lighter things being used too) instead.
