carcosa
Member since August 2017
Post by carcosa on Oct 7, 2017 9:18:36 GMT -5
Hopefully you can see the pictures above, working on gluing the surrounds at the moment. The motor has arrived so should be done in the next week. I may need to alter the spacers and wheel order, but I'm pleased with the progress and look forward to getting to work on it.
Post by Deleted on Oct 7, 2017 10:11:57 GMT -5
Hopefully you can see the pictures above, working on gluing the surrounds at the moment. The motor has arrived so should be done in the next week. I may need to alter the spacers and wheel order, but I'm pleased with the progress and look forward to getting to work on it. We can it looks terrific so far. Can't wait to see the surrounds. What will us use for spacers between the wheels? Love the merkaba on the fireplace. ETA Next time, include the doggos!
carcosa
Post by carcosa on Oct 7, 2017 12:00:29 GMT -5
Thanks. The motor is here and I'm awaiting my father in law to sort out the wiring. Should finish gluing tonight. Need to attach drainage to my trays using a beer keg taps, which I used on my previous set up. Just need to figure out water system for wheels. I used a gravity feed system before so hoping I can use the same system again. The spacers are stainless steel and are already on the shaft, just need to swap them about to even up the spacing. I love my fireplace too, it's half moon around the hearth and stepped on the top, quite Art Deco in style. As for the doggos only puddy cats here. Although I was brought up with dogs so love them too.
carcosa
Post by carcosa on Oct 10, 2017 11:20:24 GMT -5
Housing made, motor attached just water feeds, drainage and cover for belt/bearings Attachments:
carcosa
Post by carcosa on Oct 13, 2017 16:44:15 GMT -5
Just the water holes to drill and drainage to sort. Moving along quickly now
