vwfence
Post by vwfence on Sept 2, 2017 9:12:17 GMT -5
Does anyone know whether to get bearings for Poly arbors ? the bearing in them is a 87504 that is .750 ID and 1.850 OD . I Ordered new 87504 bearings and now they are 20 MM ID and an OD I didnt bother to check . Thanks for any help . Wayne
Post by Fossilman on Sept 2, 2017 14:19:20 GMT -5
Hey Quartz......."Larry"..........Do you have the answer??? "BUMB-ing this up"
Post by Deleted on Sept 2, 2017 16:54:51 GMT -5
minerken
Member since August 2013
Post by minerken on Sept 2, 2017 17:44:54 GMT -5
I copied this from another forum's archive in fact Bobby1 initiated the same question as you have.
"If they are like my Poly arbor, they are exactly the same as Lortone units. They are held in place by a setscrew on a collar, the bearings are mounted in rubber and are very long lasting. I just replaced mine after 40 years.The bearings and rubber mounts are available from Lortone at a higher price take Tony Funks advice and order from them. I should have added at start this is for 3/4 inch shaft unit."
Post by coloradocliff on Sept 2, 2017 17:53:59 GMT -5
Be awful hard to beat johnjsgems on anything lap equipment related. He might be getting ready for the big Denver show this upcoming weekend.
vwfence
Post by vwfence on Sept 2, 2017 19:58:29 GMT -5
these bearings are not mounted in rubber and are totally different from the bearings I have replaced in different machines from Lortone and Lortone shafts are either 1/2 or 5/16th and these Polys are 3/4 shafts
minerken
Post by minerken on Sept 2, 2017 21:04:48 GMT -5
Ok maybe this will work on evilbay they sell some NOS JAF 87504 bearings. Maybe they are .75 since they are older. but they don't list the specs.
Post by quartz on Sept 2, 2017 22:51:06 GMT -5
vwfence
Post by vwfence on Sept 4, 2017 11:13:58 GMT -5
I have sent a message to FAFNIR to see if they make a bearing that size anymore . It appears that a lot of the older bearing numbers have been changed to metric dimensions for some reason . I did find some .750 ID bearings with a 1.625 OD and I am going to see if I can find some steel shim stock that is .110 and I may try that . Thanks for the Applied site Larry but at that price 2 bearings are more than a poly arbor sells for here . I could probably get a new shaft turned cheaper. Wayne
Post by quartz on Sept 4, 2017 12:09:31 GMT -5
The idea of putting the Applied site up is that it makes a good search/reference site for what is available, not necessarily the only or best place to buy. Have a look around at some other bearing sites.
minerken
Post by minerken on Sept 4, 2017 14:41:59 GMT -5
minerken
Post by minerken on Sept 4, 2017 15:03:39 GMT -5
vwfence
Post by vwfence on Sept 4, 2017 17:19:23 GMT -5
Does anyone know why the bearing companys switched from American Standard to metric and didn't use different bearing numbers ?? I have access to a lathe with a 48 inch bed so turning isn't a major issue to take a piece of 1 inch shaft and turn it down and probably a person could buy a shaft from Lortone in 5/8ths dia . that is close enough in length to make it work .
minerken
Post by minerken on Sept 4, 2017 22:50:56 GMT -5
Lortone's 8 inch Arbors
Kingsley North → Lapidary Equipment & Supplies → Grinding & Polishing Arbors
A heavy duty 8" cast aluminum lapidary arbor with a 3/4" shaft, sealed ball bearings and plated flanges. Complete with a 3 step pulley and drive belt. Motor can be mounted in rear or under bench. Basic model measures 16-½" long x 5-½" high, with 2-½" shaft extension. Long shaft model measures 34" long x5-½" high, with 8-¼" shaft extension. FREE SHIPPING IN CONTINENTAL 48 STATES - GROUND ONLY
Lorton Sealed ball bearing, hardened races with set screws, extended inner race & dirt slinger with seal. Fits All TS8, FS8, LS10 and LS12. Also Fits BA, LU6X, NS8 and MaxPro models manufactured after Jan. 1, 2005. (Models manufactured 2004 and prior also order 240-069 Bearing Isolator.) Shipping weight 6 oz. ea. #200-006 $ 16.90 Bearing Isolators Molded rubber to reduce vibration. Fits BA, NS8, Lu6x and MaxPro models manufactured after Jan. 1, 2005. Use with 200-006 bearing only. #240-069 $7.20
according to lorton their arbors are for 3/4 shafts so maybe the guy on the other forum was right. Just saying
