mikeinsjc
Member since June 2010
Post by mikeinsjc on Sept 10, 2017 18:31:44 GMT -5
Those of you living in Florida are encouraged to shoot at Irma. There are several reasons for this.
The first, and most obvious, is that you might hit a shark. As I learned from the Sharknado series, this would be a good thing.
If Irma is from global warming, running off a clip through your AR will send global warming a message that you do not intend to sit idly by and do nothing.
Looters may hear the sounds and get frightened off.
If everyone shoots into the wind, it should help slow the hurricane down. Theoretically.
Post by vegasjames on Sept 10, 2017 18:39:10 GMT -5
Those of you living in Florida are encouraged to shoot at Irma. There are several reasons for this. The first, and most obvious, is that you might hit a shark. As I learned from the Sharknado series, this would be a good thing. If Irma is from global warming, running off a clip through your AR will send global warming a message that you do not intend to sit idly by and do nothing. Looters may hear the sounds and get frightened off. If everyone shoots into the wind, it should help slow the hurricane down. Theoretically. Or we can just throw Hillary in their. That will freeze the hurricane in place.
