minerken
Member since August 2013
Post by minerken on Sept 12, 2017 14:07:36 GMT -5
So I'm in the process of finishing my new shop. I wanted to make it as fire proof as possible so I used cement board over wood for the floor. I live in a high snow area so need to seal this some way I have considered two different methods 1. self leveling cement 2. Rustoleoum type resin coatings. I like the idea of the SLC but it too would have to be sealed and it is really not sold as a wear surface material but an underlay-ment. things roll around pretty easily as is but needs a little more leveling. Any of you have any other options or suggestions as to different products?
Post by manofglass on Sept 12, 2017 17:55:06 GMT -5
Tile the floor
Walt
agatemaggot
Member since August 2006
Post by agatemaggot on Sept 12, 2017 19:18:44 GMT -5
Think about a self adhesive tile, some of the wood patterns are a real knockout ! They go on fast and wear great, easy clean up.
spiritstone
Member since August 2014
Post by spiritstone on Sept 12, 2017 19:24:16 GMT -5
I was going to say the same thing. If you dont want the floor to feel cold on the feet, go with vinyl floor planking or carpet tile?
Post by fantastic5 on Sept 12, 2017 19:31:58 GMT -5
X2 on the tile. You've already got the cement board. Our Habitat for Humanity Restores usually have tile dirt cheap.
Post by Pat on Sept 12, 2017 19:45:28 GMT -5
My workshop has a cement floor. Gets very cold in the winter, so I wear fuzzy-lined snow boots. Ah, warm feet!
Post by spiceman on Sept 12, 2017 20:05:05 GMT -5
What ever type of tile you pick, make sure it's not too smooth. Very slippery when wet. Could be. Cement is a good idea,a rough texture and seal it. Just a thought.
minerken
Post by minerken on Sept 12, 2017 20:51:27 GMT -5
That may be a partial answer I could maybe tile a small part of it but machining is my other hobby and heavy iron falling may not be compatible. I actually am really asking if any one here has a good recommendation as to one of the resin based cement sealers that would work over the cement board. I think I've eliminated the self leveling cement because it will probably be brittle and break the cement board has the fiberglass reinforcement so it should be able to give with temp changes etc.
spiritstone
Post by spiritstone on Sept 12, 2017 21:08:07 GMT -5
spiritstone
Post by spiritstone on Sept 12, 2017 21:29:50 GMT -5
Whoops, on the burn resistant resin, I was typing out loud. lol Go with a durable rubber flooring.
minerken
Post by minerken on Sept 12, 2017 23:46:10 GMT -5
spiritstone I had not heard of those rather expensive but I'll sure look at those closer. As for burn resistant you are right they aren't but they are none flammable so they wont contribute as a fuel,melt ya but not flame.Maybe I have left out a little info here is my shop another view so as you can see it's on skids which are on cement blocks but I think you can understand that there is probably going to be heaving and settling for several years . I want something flexible so cement board rather than a thin cement or tile floor. I guess these are the type of products I am leaning towards just hoping that some of you may have used them and can recommend one brand over the other or know someone that has used it. www.amazon.com/s/ref=nb_sb_ss_i_3_12?url=search-alias%3Daps&field-keywords=garage+floor+epoxy&sprefix=garage+floor%2Caps%2C237&crid=7PQGQEFP65B4
Post by Deleted on Sept 13, 2017 9:37:10 GMT -5
If it was me, I would epoxy coating that floor and be done with it. Hot chips may char tiny spots so go dark color. Lol
Post by coloradocliff on Sept 13, 2017 9:47:21 GMT -5
spiritstone I had not heard of those rather expensive but I'll sure look at those closer. As for burn resistant you are right they aren't but they are none flammable so they wont contribute as a fuel,melt ya but not flame.Maybe I have left out a little info here is my shop another view so as you can see it's on skids which are on cement blocks but I think you can understand that there is probably going to be heaving and settling for several years . I want something flexible so cement board rather than a thin cement or tile floor. I guess these are the type of products I am leaning towards just hoping that some of you may have used them and can recommend one brand over the other or know someone that has used it. www.amazon.com/s/ref=nb_sb_ss_i_3_12?url=search-alias%3Daps&field-keywords=garage+floor+epoxy&sprefix=garage+floor%2Caps%2C237&crid=7PQGQEFP65B4 Really nice to have the extra space and gets you out of momma's hair more. My only suggestion is to start building another because you'll be out of room again shortly.grin Would take an aircraft hanger for most of us. Good deal Ken !
Post by fantastic5 on Sept 13, 2017 9:58:25 GMT -5
We just sealed a couple of newly poured concrete pads with: Not sure if it would work for concrete boards, but I would think it would.
minerken
Post by minerken on Sept 13, 2017 13:14:12 GMT -5
fantastic5 now that is what the type of product info I am looking for thats a brand I had not considered and I see it is available through Lowes. I see it has a solvent in it I think I'll call the manufacturer and see if it will affect the fiberglass mesh thanks! coloradocliff boy howdey I hear you loud and clear the building is a 12'x24' so only 288sqft and my current shop is 400sqft but poorly organized so it's going to be cozy to say the least, unfortunately I had no other choice (county building and setback codes) Scott exactly exactly my thoughts just deciding on the best product but not going to mess around too much longer
minerken
Post by minerken on Sept 14, 2017 20:18:12 GMT -5
fantastic5 thanks a bunch it started me thinking in a different direction and wound up using that type of product actually just ordered it.I actually wound up getting a water based instead of the solvent based witch is combustible. Thanks again
