Post by TheRock on Sept 28, 2017 18:22:50 GMT -5
Post by TheRock on Oct 1, 2017 20:06:07 GMT -5
Luminin
Member since August 2017
Post by Luminin on Oct 1, 2017 20:10:05 GMT -5
That is quite a tidy job! Should cut back on the noise (I just have rotaries, are the vibes loud?) and having to chase them around a table! 😂
Post by TheRock on Oct 1, 2017 21:56:02 GMT -5
That is quite a tidy job! Should cut back on the noise (I just have rotaries, are the vibes loud?) and having to chase them around a table! 😂 Thanks Luminin! Well first lemme commend you on getting your Avatar Straightened up and flying right! It was making my neck hurt being 90deg out of sink! Well I am just going by the destruction's but trying to make them look as nice as possible. Yeah they say in the destruction's the Vibe can walk across the table and your not suppose to bolt them down to the table cause they can cause all kinds of trouble like tools vibrating off the bench. Since they don't want you bolting this down to a bench I figure once I set it on the Bench I want it to look good instead of some Elmer Fudge Rigged Job. I don't have a Couple nice Rocks for this purpose so I did the best job I could with a Concrete Block the method most Hounds Use. Cheers ~Duke
Post by captbob on Oct 2, 2017 0:31:11 GMT -5
If you're gonna do something, do it right. The above, Mr. Duke, is doing it right! Nice job.
Post by TheRock on Oct 2, 2017 12:21:57 GMT -5
If you're gonna do something, do it right. The above, Mr. Duke, is doing it right! Nice job. Thank's Capt'n Well late last night I trimmed off all the excess glue masked off the tumblers and gave it a paint job. This morning I unmasked both of the tumblers and they don't look too bad. There is a slight touch up there needs to be done with an ARTIST Brush that I will have MaryJane do that's the wife her hand is steadier than mine. So we will call this done for now till the rocks go in maybe follow up with a Youtube Video. Cheers ~Duke
Post by TheRock on Oct 2, 2017 12:43:48 GMT -5
Oh there was one more question I was going to ask, why couldn't a guy add a toggle switch in this location right here? I don't understand why any of these machines do not have a switch installed? Thanks ~Duke
