Post by rockjunquie on Oct 9, 2017 11:38:25 GMT -5
I'm praying none of our members suffer any loss in all the fires. Well, I really hope NO ONE does, but I saw the news and lots of people are wiped out. My heart goes out to all of those people.
Are we all accounted for? I hope so. We have so many CA members.
Post by Deleted on Oct 9, 2017 14:27:06 GMT -5
We good!
Post by Pat on Oct 9, 2017 15:53:59 GMT -5
Good here, too. Lots of smoke everywhere. Can’t see surrounding hills.
Post by Bluesky78987 on Oct 9, 2017 18:01:39 GMT -5
Good here. Protected by a vast sea of concrete.
Post by Deleted on Oct 9, 2017 18:22:11 GMT -5
One big one is 15 miles due south of my place. <'))))>< Fish may be affected
<'))))>< Fish
Gone Fishing
Member since April 2005
Post by <'))))>< Fish on Oct 9, 2017 20:34:31 GMT -5
I'm fine, fire is not near me
Post by gmitch067 on Oct 9, 2017 20:54:11 GMT -5
I'm good Tela. Air quality is the pits though.
Post by rockjunquie on Oct 9, 2017 21:01:19 GMT -5
One big one is 15 miles due south of my place. <'))))>< Fish may be affected I hope you're keeping a close eye on it!
Post by Deleted on Oct 9, 2017 21:06:53 GMT -5
One big one is 15 miles due south of my place. <'))))>< Fish may be affected I hope you're keeping a close eye on it! Thanks for your kind thoughts. Sincerely. Thank you. 😘 I'm upwind. The dry desert winds are currently fanning the flames. If the winds reverse, and they may, the ocean will give flame cooling humidity and push the fires back towards already burned area. Plus, those 15 miles are full of concrete and residential housing. Not much fuel comparatively.
Post by rockjunquie on Oct 9, 2017 21:08:55 GMT -5
I hope you're keeping a close eye on it! Thanks for your kind thoughts. Sincerely. Thank you. 😘 I'm upwind. The dry desert winds are currently fanning the flames. If the winds reverse, and they may, the ocean will give flame cooling humidity and push the fires back towards already burned area. Plus, those 15 miles are full of concrete and residential housing. Not much fuel comparatively. That's good to hear, but never trust fire.
Post by Pat on Oct 9, 2017 21:13:40 GMT -5
Anyone hear of the cause of any of these fires?
Sam Jose fine except for bad air and smoke.
Post by Deleted on Oct 9, 2017 21:17:35 GMT -5
Anyone hear of the cause of any of these fires? Sam Jose fine except for bad air and smoke. aDave can explain. My opinion? firebugs with a propensity to be "gratified" by setting fires. They wait for these conditions and hit places they scouted thru the rest of the year.
Post by Pat on Oct 9, 2017 21:22:25 GMT -5
I felt a small earthquake about 5:49pm today. Preliminary usgs estimated 4.1. Felt right under where I was sitting.
Post by vegasjames on Oct 9, 2017 21:39:06 GMT -5
Anyone hear of the cause of any of these fires? Sam Jose fine except for bad air and smoke. Doubt they will even investigate until after the fires are out since that is more important. Can be from a lot of things. Backfire from a vehicle, someone playing with matches, or burning trash, campfires, someone throwing a cigarette out the window, a spark from tools, etc. We have had fires here from people target shooting and the bullets sparking on rocks. The said they think some of the secondary fires were from embers from the primary fire being carried by the high winds.
Post by Garage Rocker on Oct 9, 2017 21:39:19 GMT -5
Fires, earthquakes and a goofball governor. I don't know how you guys do it.
Post by Deleted on Oct 9, 2017 21:42:37 GMT -5
Fires, earthquakes and a goofball governor. I don't know how you guys do it. The first two are nearly meaningless for 99.9% of the population. The last is, I'm learning, a bunch of poo that really has nearly zero effect on my daily life.
Post by orrum on Oct 10, 2017 9:12:16 GMT -5
Is Tommy ok? Not heard from him.
Post by Deleted on Oct 10, 2017 10:56:40 GMT -5
Tommy is fine. He and Eva own a house in Napa that is fine for now. They are watching the news 24/7
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Oct 10, 2017 13:27:55 GMT -5
Everyone stay safe out there.
Post by aDave on Oct 11, 2017 12:50:47 GMT -5
Anyone hear of the cause of any of these fires? Sam Jose fine except for bad air and smoke. aDave can explain. My opinion? firebugs with a propensity to be "gratified" by setting fires. They wait for these conditions and hit places they scouted thru the rest of the year. Doubt they will even investigate until after the fires are out since that is more important. Can be from a lot of things. Backfire from a vehicle, someone playing with matches, or burning trash, campfires, someone throwing a cigarette out the window, a spark from tools, etc. We have had fires here from people target shooting and the bullets sparking on rocks. The said they think some of the secondary fires were from embers from the primary fire being carried by the high winds. I have not heard anything related to cause(s) of the different fires. I've kind of been out of the loop, and I haven't gone searching for the info. That said, vegasjames hit on alot of the more frequent wildland fire causes. High winds can also cause problems with electrical lines being downed also. One note about cigarettes, however, is that they typically get blamed (IMHO) for more fires than they actually cause. Conditions have to be right humidity wise, and I hadn't seen numbers (in Santa Rosa specifically) that would support a cigarette caused fire. Then again, some of he humidity numbers I saw were a couple days into the fire. Of course, as @shotgunner mentioned, the fire(s) could have intentionally set. If I was a betting man, they probably started working on the scene investigation as soon as the fire burned out of the area of origin. Most investigative personnel don't have suppression duties, so they wouldn't be pulling staff away from actually working on the fire. Even if it wasn't safe to go into the scene right away, the investigative branch was probably already working on gathering witness info as early as possible. Dave
