Post by Drummond Island Rocks on Jan 8, 2018 18:00:06 GMT -5
Iv'e been doing a bunch of experimenting with Petoskey stones in a lortone 3 pound barrel. The rock shed has a recipe that was posted here a couple months ago so I started with that and tweaked as needed. This is my personal best for Petoskey stones. They actually have a wet shine. Thanks for looking Chuck
Post by MsAli on Jan 8, 2018 18:01:17 GMT -5
Those look great
70karmann
Member since February 2011
Post by 70karmann on Jan 8, 2018 18:22:59 GMT -5
Good job on a difficult item.
Post by Jugglerguy on Jan 8, 2018 18:45:48 GMT -5
Holy crap!!!
Post by Drummond Island Rocks on Jan 8, 2018 19:01:27 GMT -5
Hopefully these results can be repeated. Maybe I should have taken some notes? There is a line from a Jerry Reed song that I think fits. The song is Eastbound and down and the line is "Were gonna do what they say can't be done" Chuck
Post by rmf on Jan 8, 2018 19:24:56 GMT -5
Take good notes and share your recipe, please.
Post by taylor on Jan 8, 2018 19:28:08 GMT -5
Very nice!!!
Post by Jugglerguy on Jan 8, 2018 19:54:15 GMT -5
I'm looking forward to trying this on Kona dolomite too. I'm placing a Rock Shed order right now.
Post by Drummond Island Rocks on Jan 8, 2018 20:01:43 GMT -5
I'm looking forward to trying this on Kona dolomite too. I'm placing a Rock Shed order right now. There was one lower quality Petoskey stone that did not come out very shiny. As usual garbage in equals garbage out. I put 10 more stones in the same polish mix today with out adding anything. I am surprised you still have Kona kicking around. Did you go again or still have some from that one trip years ago? Chuck
Post by Jugglerguy on Jan 8, 2018 20:04:44 GMT -5
I am surprised you still have Kona kicking around. Did you go again or still have some from that one trip years ago? Chuck I've gone to the quarry twice, but the last time was about three years ago. It's just been sitting in my basement taking up space. It's almost all big chunks. I'll have to go buy a bigger hammer if this method works. How long did you end up running the polish stage?
Post by fernwood on Jan 8, 2018 20:14:15 GMT -5
OMG! Those are beautiful. A lot less work, I am sure than my hand polishing for one. I had looked at the Rock Shed recipe for tumbling, and used some of those suggestions in my hand polish.
You are on to something, and will understand if you do not share the recipe. but, please do.
Post by Drummond Island Rocks on Jan 8, 2018 20:20:10 GMT -5
I've gone to the quarry twice, but the last time was about three years ago. It's just been sitting in my basement taking up space. It's almost all big chunks. I'll have to go buy a bigger hammer if this method works. How long did you end up running the polish stage? These went about 48 hours in polish. Just 7 small stones in a 3 pound barrel. Very full barrel with filler to about 85 percent and heavy water. I did not keep great notes so I want to try it again while its fresh in my mind and maybe take some notes and pictures along the way. I should have mentioned earlier that these are the higher quality East side Petoskey stones. Chuck
Post by Jugglerguy on Jan 8, 2018 20:35:33 GMT -5
These went about 48 hours in polish. Just 7 small stones in a 3 pound barrel. Very full barrel with filler to about 85 percent and heavy water. I did not keep great notes so I want to try it again while its fresh in my mind and maybe take some notes and pictures along the way. I should have mentioned earlier that these are the higher quality East side Petoskey stones. Chuck I think that's a myth that Lake Michigan Petoskeys are higher quality. I've picked good and bad in both lakes. I'll stand behind my Huron Petoskey stones any day.
Post by Drummond Island Rocks on Jan 8, 2018 20:50:44 GMT -5
These went about 48 hours in polish. Just 7 small stones in a 3 pound barrel. Very full barrel with filler to about 85 percent and heavy water. I did not keep great notes so I want to try it again while its fresh in my mind and maybe take some notes and pictures along the way. I should have mentioned earlier that these are the higher quality East side Petoskey stones. Chuck I think that's a myth that Lake Michigan Petoskeys are higher quality. I've picked good and bad in both lakes. I'll stand behind my Huron Petoskey stones any day. I was trying to brag on your East side stones. Might even be enough to solidify Tommy's trip plans. Chuck
Post by jamesp on Jan 9, 2018 0:52:08 GMT -5
This fluorite had a decent polish but a common problem was the rough surface as seen in the glare on the left stone. Never could figure out how to get around that. Certain it is a product of tumbling where a wheel won't do that. Great achievement Chuck. 85% fill is another world, makes sense heading in that direction especially with small barrel. I have been running those 8.5" HDPE barrels at 63 RPM with 85% fill, 50% 1/2 inch pea gravel and getting total bruiseless satin finish on glass. You can barely hear the rocks in the barrel, totally gentle.
tkvancil
Member since September 2011
Post by tkvancil on Jan 9, 2018 10:37:33 GMT -5
Those turned out great! Thanks for sharing.
ontherocks
Member since May 2017
Post by ontherocks on Jan 9, 2018 17:19:40 GMT -5
Amazing shine. The best I think I have seen.
Post by jamesp on Jan 10, 2018 5:20:48 GMT -5
Looking forward to the 'how to' Chuck. Congrats on this accomplishment. Would not surprise if rotary tumblers may be a better tool for soft rocks.
ChicagoDave
Member since June 2016
Post by ChicagoDave on Jan 10, 2018 9:00:10 GMT -5
That is a great shine!
illusionist
Member since August 2017
Post by illusionist on Jan 13, 2018 14:16:04 GMT -5
Wow!
