Post by MsAli on Jan 8, 2018 22:43:59 GMT -5
manofglass sent me some really cool stuff to play with, some of which was Preforms. Walt has been so kind and generous and I can't thank him enough. He said it was ugly stuff and I'm to make them beautiful. So I decided to try to cab using just my dremel. Here's what I've got so far Picture 3 is shown wet Tips please!! Walt- what stone is this? Has softer spots that are given me a fit
Post by MsAli on Jan 8, 2018 22:49:28 GMT -5
Pictures did not pick up the blue in it
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Jan 8, 2018 22:57:15 GMT -5
I can't tell from the picture. Undercutting, where the soft material wears faster is hard to overcome. I try really light pressure.
Post by manofglass on Jan 8, 2018 22:59:14 GMT -5
Looks good
Walt
Post by MsAli on Jan 8, 2018 22:59:27 GMT -5
I can't tell from the picture. Undercutting, where the soft material wears faster is hard to overcome. I try really light pressure. I'l try to get better pictures when I get back home, but there's a spot on the side that is very soft. More grinding to do to try to get past it.
Post by MsAli on Jan 8, 2018 23:00:30 GMT -5
You are so kind and helpful. Thank you.
Post by MsAli on Jan 9, 2018 1:20:19 GMT -5
Added pics
fishnpinball
Post by fishnpinball on Jan 9, 2018 13:09:07 GMT -5
wow that really shows up as a different color. I have not seen that material unless it is k2 granite.
Post by MsAli on Jan 9, 2018 13:14:47 GMT -5
wow that really shows up as a different color. I have not seen that material unless it is k2 granite. I am having a hard time catching the true color of it. Light grey w/ blue spots.
Post by Peruano on Jan 9, 2018 19:14:11 GMT -5
From my viewpoint you are trying to run a race with a mack truck tied behind you. If you can cab with a dremel, you will be carving nymphs from travertine in no time. Congratulations on what you have done. You indeed are learning a lot about the stone and the tool. Stones of varying hardness are a challenge, but can be dealt with by adjusting pressure, the angle of attack, and by adjusting your design/shape. Once you get the shape you want and have your stone domed, you can probably finish it by hand if need be. Keep us informed.
Post by MsAli on Jan 9, 2018 22:12:36 GMT -5
Uugghh a lot of flaws, but getting there
Post by MsAli on Jan 9, 2018 22:13:53 GMT -5
I think I'll go back and shape it some more
Post by Pat on Jan 9, 2018 22:16:54 GMT -5
Good for you! You are in your way. 👍🏻
Post by vegasjames on Jan 9, 2018 23:27:29 GMT -5
Its taking shape. Maybe coat the stone with epoxy to fill the pits and create a harder surface then repolish it.
Post by MsAli on Jan 9, 2018 23:30:23 GMT -5
Its taking shape. Maybe coat the stone with epoxy to fill the pits and create a harder surface then repolish it. Thank you-I will try that!
Post by MsAli on Jan 9, 2018 23:32:58 GMT -5
Little better picture. I'd like to know what stone it is. Think I picked a hard one for my first go
Post by youp50 on Jan 10, 2018 3:55:59 GMT -5
Please wear respitory protection.
You are demonstrating above average eye to hand coordination.
Post by MsAli on Jan 10, 2018 9:01:22 GMT -5
Please wear respitory protection. You are demonstrating above average eye to hand coordination. No worries, I am and also my eye protection. Thank you 😊
Post by manofglass on Jan 10, 2018 12:39:34 GMT -5
This is the stone that alikat218 cab came out of walt
Post by rockjunquie on Jan 10, 2018 14:32:33 GMT -5
You're proving that persistence pays off. Great job on a difficult task!
