Post by rockjunquie on May 17, 2018 10:44:47 GMT -5
Post by fantastic5 on May 17, 2018 11:54:15 GMT -5
I did see this email from Rio. But my William Holland teacher last year taught us to use White Out Correcting Fluid. I've used it several times and have not had trouble with the solder running and joining pieces that I didn't want soldered.
Post by fernwood on May 17, 2018 11:55:45 GMT -5
Looks like a great and useful item.
Post by rockjunquie on May 17, 2018 12:23:21 GMT -5
I did see this email from Rio. But my William Holland teacher last year taught us to use White Out Correcting Fluid. I've used it several times and have not had trouble with the solder running and joining pieces that I didn't want soldered. Good to know. I knew abt it but haven't tried it.
Post by opalpyrexia on May 28, 2018 11:35:35 GMT -5
A tube of watercolor paint - any one of the sienna colors - also works well. Brush it on from the tube with little or no dilution.
Post by Rockoonz on May 29, 2018 1:41:29 GMT -5
I've used white out as well, it would be interesting to compare to mud or sienna paint. I don't see ease of cleaning as that big of an issue since it's going to take pickle to remove the flux anyway.
Post by rockjunquie on May 29, 2018 6:41:10 GMT -5
A tube of watercolor paint - any one of the sienna colors - also works well. Brush it on from the tube with little or no dilution. I'm assuming the colors with ocher in it, right?
Post by opalpyrexia on May 29, 2018 9:09:02 GMT -5
Yes, I believe that any of the pigments that include iron oxide would work.
timloco
Member since April 2012
Post by timloco on May 29, 2018 12:16:31 GMT -5
I've had good luck with yellow ochre... Not sure why I'd want to use this instead.
Post by opalpyrexia on May 29, 2018 13:37:55 GMT -5
I just had to look up yellow ochre and learned this from Wikipedia: "The major ingredient of all the ochres is iron(III) oxide-hydroxide, known as limonite, which gives them a yellow colour." So it also has iron oxide.
Post by toiv0 on May 30, 2018 4:49:55 GMT -5
I was given a half a jar, couple cups of yellow ocre powder and its what I use.
