kirja
Member since September 2018
Post by kirja on Sept 26, 2018 12:24:41 GMT -5
Hi all i am Kirja African gem colletor , long time a go i am moving from mountain to other ,from desert to other , and from forest to other , until i had big infirmations about rough stones , at last i found a place in my countory which is full corundum all colors , pink ,blue , red ، yellow ,pi-color ,multi color , but that corundum is coated with strong white cover it , i tried all grinding machines and all the chemical in my countory but no result ,, please i need some one who test any way for making the corundum stones transparent , clear,and shiny. Thanks all. Best regards. Sorry for my weak English it not my mother langue.
Post by MsAli on Sept 26, 2018 14:30:14 GMT -5
Hi and welcome Can you take pictures and show us what you mean by "but that corundum is coated with strong white cover it"?
Post by TheRock on Sept 29, 2018 15:26:19 GMT -5
Welcome to RTH Forum from ~Duke in SW/Michigan
Post by vegasjames on Sept 29, 2018 16:21:03 GMT -5
Welcome to the forum.
Not all corundum can be made clear.
As for the white coating without knowing what that coating is it is hard to say what will work to remove it.
gemfeller
Member since June 2011
Post by gemfeller on Sept 30, 2018 0:23:42 GMT -5
Welcome to the Forum Kinja. As vegasjames posted, clear, clean corundum is the exception. Much of it has internal fractures or inclusions that lower its value. If your crystals are simply coated with some substance, that may be a different matter. If you want to send me a few typical crystals with the coating I'd be happy to see if I can find a way to remove it. I can have it checked by professional gemologists as well if warranted. I'll return anything you send of course.
Post by Fossilman on Sept 30, 2018 9:10:38 GMT -5
Welcome to RTH..
