Post by pauls on Dec 9, 2018 1:06:41 GMT -5
For your resin idea, what about car dent filler, you wouldn't need much of a mold for that. just a cardboard tube would hold for the couple of minutes for it to set. It would be easy to use too just mix the diamond in the filler first then add the catalyst and plaster it in your mold. It would need to be run wet otherwise the resin could melt and make a real mess.
meandgod67
Member since June 2019
Post by meandgod67 on Jun 8, 2019 6:24:46 GMT -5
Can I get info on how to make a sphere machine? I can get the diamond heads and the motors but don’t know the setup. Can someone point me in the right direction or show me a rough blueprint of how to get set up? I want to make 2-3 inch spheres as gifts. I have a 18 pound vibratory tumbler
AzRockGeek
Member since September 2016
Post by AzRockGeek on Jun 8, 2019 12:43:31 GMT -5
Can I get info on how to make a sphere machine? I can get the diamond heads and the motors but don’t know the setup. Can someone point me in the right direction or show me a rough blueprint of how to get set up? I want to make 2-3 inch spheres as gifts. I have a 18 pound vibratory tumbler Glance through all threads in this folder, you will find what looking for. Also, search the DIY projects under lapidary equipment.
Rockshund
Member since July 2019
Post by Rockshund on Jul 31, 2019 15:43:32 GMT -5
Beautiful spheres Kilgore! I'm working on a homebuilt machine now. I have heard of people doing what you suggest with the epoxy. I would try to find a zero VOC epoxy (no volatiles) to avoid shrinkage!
