dreamrocks
Member since November 2018
Post by dreamrocks on Nov 25, 2018 16:00:12 GMT -5
Hello from dream rocks, I am new to tumbling I have a tumble vibe 5 that i am learning to use. I also have a cab king that I use for cabbing. What I am trying to do with the tumble vibe is tumble my gem rough for faceting and am experimenting with finishing several cabs in the tumbler at once. I work with a lot of Montana agate, dendritic agate from madagascar a few agates from maine there's not much agate in maine to work with maine beryl and jasper. I would like to be able to use my tumbler to get as good or better finish than my cab king can. By the time I get to the 3000 grit my cabs look polished already this is the finish I am trying to accomplish with the tumbler. The stones that I have tumbled almost look frosted or hazy not clean and polished like on the cab king. Far as posting any pictures, well that has been just as challenging sometimes the threads are to I hit great thread everything disappears.
dreamrocks
Post by dreamrocks on Nov 25, 2018 16:01:33 GMT -5
Ok so far so good did not disappear yet!
dreamrocks
Post by dreamrocks on Nov 25, 2018 16:20:12 GMT -5
My last attempt at putting up a picture.
Post by vegasjames on Nov 25, 2018 21:50:19 GMT -5
Welcome to RTH.
Try using a host for your pics such as Flickr. Then you can copy the code for the pic in your post and the picture will show in your post.
dreamrocks
Post by dreamrocks on Nov 26, 2018 8:14:25 GMT -5
Thank you
Post by hummingbirdstones on Nov 26, 2018 8:34:31 GMT -5
Welcome from Northern Arizona!
dreamrocks
Post by dreamrocks on Nov 26, 2018 9:21:53 GMT -5
Thank you!
Post by As I in does tries! on Mar 4, 2019 16:44:21 GMT -5
Greetings from Scotland, United Kingdom!
I currently have the following Lortone QT12/66 rotary tumbler, Lortone C300 rotary tumbler, 2x Viking Vibrasonic 2x 14lb and 2x 6lb hoppers (Diamond Pacific) (USA) vibrating tumblers, Hans lapidary 6 wheel rock grinder and polisher, 6 inch blade and wheel combo unit that is currently under redevelopment, with Silicon Carbide grit Fixed80, F220, F600, F1200, with Tin Oxide (1.0 micron) and Aluminum Oxide (0.3 micron) polishes.
ivan
Member since March 2014
Post by ivan on Mar 4, 2019 16:52:20 GMT -5
Greetings & Salutations from Pa.
