dreamrocks
Member since November 2018
Post by dreamrocks on Nov 27, 2018 17:56:54 GMT -5
Post by MsAli on Nov 27, 2018 21:31:51 GMT -5
Where do you get the settings?
dreamrocks
Post by dreamrocks on Nov 27, 2018 23:35:05 GMT -5
dreamrocks
Post by dreamrocks on Nov 27, 2018 23:37:48 GMT -5
This was made with a dremel. Still need to drill hole and put key ring on
Post by vegasjames on Nov 28, 2018 3:31:53 GMT -5
Did a great job on those.
Post by fernwood on Nov 28, 2018 5:22:23 GMT -5
Great looking pendants, rings and cabs.
dreamrocks
Post by dreamrocks on Nov 28, 2018 18:45:25 GMT -5
The scratches on the back makes it look more like rutilated quartz.
dreamrocks
Post by dreamrocks on Nov 28, 2018 22:31:19 GMT -5
Rio Grande in Blue water new Mexico
Post by beefjello on Nov 29, 2018 19:25:50 GMT -5
Nice, you sure cut a whole buncha beauties there!
dreamrocks
Post by dreamrocks on Nov 29, 2018 19:31:56 GMT -5
Where do you get the settings? Rio Grande in New mexico
dreamrocks
Post by dreamrocks on Nov 29, 2018 19:34:16 GMT -5
Great looking pendants, rings and cabs. Thank you. You do great work with those arrow heads do you sell them?
NRG
Member since February 2018
Post by NRG on Nov 29, 2018 23:50:01 GMT -5
Elegant
Post by fernwood on Nov 30, 2018 6:36:24 GMT -5
Great looking pendants, rings and cabs. Thank you. You do great work with those arrow heads do you sell them? The points are not my creations. I just supplied the rocks. They are made by a master knapper.
dreamrocks
Post by dreamrocks on Nov 30, 2018 6:41:28 GMT -5
Thank you. You do great work with those arrow heads do you sell them? The points are not my creations. I just supplied the rocks. They are made by a master knapper. I thought they were your work. Was hoping they were yours they would go nice with the ones I have been looking at them would of done a trade. Necklace and ring one I wanted to wire wrap to wear
dreamrocks
Post by dreamrocks on Nov 30, 2018 6:42:27 GMT -5
Thank you. You do great work with those arrow heads do you sell them? The points are not my creations. I just supplied the rocks. They are made by a master knapper. Yes the work does prove expertly made
dreamrocks
Post by dreamrocks on Dec 20, 2018 18:42:34 GMT -5
Busy day today! Ground flat the backs of 11 cabs today ready for polish. Finished four out of 6 cabs the two bigger need more fine tuning. Played with some fire agate and some coral. The cabs I am holding are Laguna and purple chlacedony
dreamrocks
Post by dreamrocks on Dec 20, 2018 18:46:58 GMT -5
Not very good picture and the stone needs polish
dreamrocks
Post by dreamrocks on Dec 21, 2018 23:16:44 GMT -5
The back needs a light sanding I took it off the dop stick. This is what Laguna Agate is all about. Its the colors and banding should look even better when the back gets polished.
dreamrocks
Post by dreamrocks on Dec 21, 2018 23:18:42 GMT -5
The back needs a light sanding I took it off the dop stick. This is what Laguna Agate is all about. Its the colors and banding should look even better when the back gets polished. I had to hold it up to the light to show the color and banding
