gatorflash1
Post by gatorflash1 on Nov 29, 2018 11:27:16 GMT -5
Hi -
I'm new to using other types polishing media and have heard that Cerium Oxide does a really great job of polishing agates, etc. Since it cost a bundle I'm wondering if the cost is worth it if you have to use say a tablespoon per pound of rocks. I found a kg (2.2 lbs) costs around $28-$30.
Maybe some of the tumbling wizards on the forum can give some advise regarding cerium (and other) polishes.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Nov 29, 2018 15:23:26 GMT -5
I have only used Cerium Oxide, since I started tumbling a coupla years ago. I have a Loretone QT66 with two 6 pound barrels. The Barrel would be 80% full with at least 1/3 plastic beads. I used 2 or 3 Tablespoons per barrel and had good results in 3 days and great results after a full week. I've reused the CO polish up to 4 times before throwing it out by adding 1 additional tablespoon when starting the next polish run. I was using the Pink Cerium Oxide which is the cheapest version. www.kingsleynorth.com/skshop/product.php?id=46509&catID=189
Post by Jugglerguy on Nov 29, 2018 16:35:09 GMT -5
I have never used cerium oxide for tumbling. I use aluminum oxide from The Rock Shed for every type of rock I tumble. It’s cheap and works great. I and several other people on this forum have won tumbling contests using aluminum oxide. Actually, I used OMG 2 aluminum oxide when I won the contest, but I use the cheap stuff from The Rock Shed most of the time. I’m not convinced that there is a difference. I sure can’t tell by looking at my finished rocks.
By the way, I’m using a vibratory tumbler for finishing my rocks, but I don’t think that makes a difference in the type of polish used.
Post by aDave on Nov 30, 2018 12:15:57 GMT -5
I'm all rotary, and I've only used aluminum oxide polish. With the results I'm seeing, I can't think of a reason to change. Yeah, I polish for a long time (3 weeks), but I've come to be pretty patient. Don't get me wrong, excellent results can be had at shorter durations, but I'm totally happy waiting that long.
Post by greig on Nov 30, 2018 19:21:35 GMT -5
I was given a tupperware container of cerium oxide and have tried it in both a rotary tumbler and a vibratory flat lap. Honestly, I am not really sure that I see a difference from the polish using aluminum oxide. If I were to polish a rock for a competition, for sure I would use cerium (just in case). All that said, I would like to point out that you can reuse polish. I usually dump mine because of laziness, but to save money you can filter and dry it and use it multiple times.
gatorflash1
Post by gatorflash1 on Nov 30, 2018 19:21:51 GMT -5
Thanks for the info. I use Alum Ox successfully, I just read some good things about Cerium and have never tried it.
