Post by MsAli on Dec 27, 2018 22:57:25 GMT -5
What are you using on the fire agate now to cut it? I bought a little polishing kit with some diamond blades for my dremel. Problem is the Chinese dont know how to measure so even though it says 1/8th shaft it is not. Tad small I used it anyways and it worked, but not ideal. Nothing like having a loose saw blade spinning around I'll go buy real Dremel ones this weekend
Post by hummingbirdstones on Dec 28, 2018 9:25:04 GMT -5
Depending on what model you have, you might want to get one of these adjustable checks for your Dremel. Then you don't have to worry as much about shank size and they're inexpensive. Just make sure it will work with your model.
There are plenty of sets of cheap diamond bits (I'm sure made in China) on Ebay. I've bought them before and they work fine. They come in different grits, so I would probably get 400 or 600 and higher to work fire agate. Make sure you use them with water so they last as long as possible. A small tub of water that you can dip the fire agate in as you're working it to cool it off and to dip the bit in to keep it cool and remove the rock schmutz from in between the diamonds works ok.
Post by MsAli on Dec 28, 2018 10:48:57 GMT -5
I have the 4200 quick change, so that wont work. I cannot change the collet on it and cannot for the life of me figure out how to attach the flex shaft. I got it on, but it doesn't seem to be spinning right
I am going to call Dremel and see if they can help me
Those Nova points are exactly what I need and they are cheaper there than on the other site I found them on.
Thank you!
Post by MsAli on Dec 28, 2018 11:02:45 GMT -5
NDK
Post by NDK on Dec 28, 2018 12:32:42 GMT -5
Post by MsAli on Dec 28, 2018 12:44:55 GMT -5
Thanks Nate-that might be a good idea!
Post by MsAli on Dec 29, 2018 22:07:05 GMT -5
Well so much for my dremel Started making a weird noise and I unscrewed plastic cap. Burned my hand and it looks fried in there I'll be calling them Monday
Post by MsAli on Dec 29, 2018 22:29:17 GMT -5
Actually the metal part that was suppose to be attached to the dremel is inside the plastic piece. I'll be calling them Monday
jimaz
Member since July 2018
Post by jimaz on Dec 29, 2018 23:49:58 GMT -5
Bummer!
Post by MsAli on Dec 29, 2018 23:51:20 GMT -5
Ya it really sucks. That was my polishing tool for my jewelry Oh well
Post by fernwood on Dec 30, 2018 6:23:05 GMT -5
That could have been a lot worse. Dremel should send you a new one.
Post by hummingbirdstones on Dec 30, 2018 10:27:24 GMT -5
Oh boy, that blows. You're lucky it didn't catch on fire while you were using it! Hope they replace it for you.
Post by MsAli on Dec 30, 2018 19:05:41 GMT -5
My 1st one done! Went out and worked it on the arbor This is half of the piece I started on the dremel I have the other half done as well, but couldnt get a picture
Post by MsAli on Dec 30, 2018 20:00:58 GMT -5
1 & 2 same piece. Picked up some really nice color. I was gonna stop and zapped it one more time on the 220 and PURPLE The other one not so great Both ended up pretty small
Post by fernwood on Dec 30, 2018 20:40:40 GMT -5
Those are great for first ones of this material. You really brought the fire to the surface.
Post by MsAli on Dec 30, 2018 20:45:18 GMT -5
Thank you I see some areas in the picture I need to work on They are so small, I'm missing skin
Post by hummingbirdstones on Dec 30, 2018 21:51:43 GMT -5
You did great on those for your first ones. You even found PURPLE! I'm impressed. I have some sitting here somewhere that I got years ago and have never quite been brave enough to try to cut them. I'm such a ninny. Now I'm going to have to dig them out and see if I can cut anything without killing it.
Maybe get some of that alligator tape to wrap around your fingers if you're going to cab those little guys freehand.
mossyrockhound
Member since January 2011
Post by mossyrockhound on Dec 30, 2018 21:58:35 GMT -5
Nice going! Your persistence paid off! Like that purple.
Post by MsAli on Dec 30, 2018 22:23:37 GMT -5
I wont lie, I squealed like a girl when I hit that purple and then prayed like crazy I didnt lose it
The tape is a great idea!
Mission tomorrow, get the dremel replaced
I see the benefits of using that over the arbor
And I am getting the one Nate suggested as well
Post by fernwood on Dec 31, 2018 7:10:13 GMT -5
I plan on getting some finger cots to wear. About 1" long. For those who have never heard the term, they are the little pieces of rubber with nubbies on them. Shaped like the end of a glove. Main use is to assist in turning pieces of paper or sliding paper into plastic menus. Thinking these would help protect fingers and also provide added grip.
