NDK
Post by NDK on Dec 31, 2018 10:12:58 GMT -5
Sorry to see your Dremel broke Ali. Hopefully they stand behind it. I know they originated in Wisconsin, wonder if they are still...
You really got some beautiful fire in that agate! Congratulations!
hummingbirdstones2
Vince A., 1958-2023
Member since August 2018
Post by hummingbirdstones2 on Dec 31, 2018 10:18:42 GMT -5
Ali, I'm glad you found purple in there. That's worth a little skin, right?
When you get the flex-shaft, try this for the foot pedal. Find something same height or higher than the foot pedal. Then you can rest the ball of your foot on and use your heel to regulate the variable speed pedal. You get a helluva lot better control of the speed that way and is less tiring.
Then get a 4x4 block - or whatever - and use some velcro to strap that handpiece to it so you can use both hands on the stone. If you have a small vacuum-base vises even better to hold the handpiece. HF sells those too. Just pad the jaws to not squish the handpiece.
Post by MsAli on Dec 31, 2018 10:31:23 GMT -5
Calling them right now-Wish me luck!
Post by MsAli on Dec 31, 2018 10:31:59 GMT -5
Seriously they are closed today and tomorrow---gggrrrrrr
Post by miket on Dec 31, 2018 10:54:13 GMT -5
Dang, I really like that purple! Beautiful.
Post by hummingbirdstones on Dec 31, 2018 11:09:17 GMT -5
Seriously they are closed today and tomorrow---gggrrrrrr I was wondering if they'd be open today. It is so aggravating when you have to contact customer service and they're closed. I will second your ggggrrrrrrrrrrrrr!
Post by Deleted on Dec 31, 2018 12:37:07 GMT -5
Has anyone tried using tape to protect areas on a stone that you don't want to accidently brush against while sanding/carving?
Post by MsAli on Dec 31, 2018 13:58:14 GMT -5
Has anyone tried using tape to protect areas on a stone that you don't want to accidently brush against while sanding/carving? I was thinking of that I have a piece that I was going to re-work, but there is a section I dont want to touch Thats why I need my Dremel or something to use. It was too hard on the arbor to avoid it
gemfeller
Member since June 2011
Post by gemfeller on Dec 31, 2018 14:54:54 GMT -5
Nice going! You found color! As I mentioned to you in my PM, learning to cut fire agate takes time and a lot of patience. And you'll have to kiss a bunch of frogs before you find that handsome prince. Learning how to interpret the fire planes and how they lie in any given piece of rough becomes a little easier with experience. Some stones are fairly predictable; others are like I said in my article: scrambled quartz. Keep at it. You're doing great.
Post by MsAli on Dec 31, 2018 15:09:51 GMT -5
Nice going! You found color! As I mentioned to you in my PM, learning to cut fire agate takes time and a lot of patience. And you'll have to kiss a bunch of frogs before you find that handsome prince. Learning how to interpret the fire planes and how they lie in any given piece of rough becomes a little easier with experience. Some stones are fairly predictable; others are like I said in my article: scrambled quartz. Keep at it. You're doing great. Your article has helped me a bunch-thank you so much for that! I cannot wait to do some more
unclesoska
Member since February 2011
Post by unclesoska on Dec 31, 2018 19:54:16 GMT -5
Nice going! You found color! As I mentioned to you in my PM, learning to cut fire agate takes time and a lot of patience. And you'll have to kiss a bunch of frogs before you find that handsome prince. Learning how to interpret the fire planes and how they lie in any given piece of rough becomes a little easier with experience. Some stones are fairly predictable; others are like I said in my article: scrambled quartz. Keep at it. You're doing great. Is there a link you'd be willing to share for this article?
gemfeller
Post by gemfeller on Dec 31, 2018 21:29:01 GMT -5
unclesoska , easy-peasy. Just click on my website link in one of my posts and scroll down on the Home Page to "Fire Agate: A Cutter's Guide." It's an old piece I wrote long ago and needs much updating and more detail but it covers some basics that might be helpful. Let me know if it helps.
Post by MsAli on Jan 2, 2019 11:10:27 GMT -5
Spoke with Dremel -no problem getting a replacement for that
Turns out it was d/c due to issues so I will be getting the new 4300
Unfortunately it wont be here till next week
Post by MsAli on Jan 8, 2019 23:51:02 GMT -5
Got my replacement and so far this model is a whole lot easier to use Fire agate #2 has a layer of caked mud on the bottom that I'm slowly peeling off
Post by miket on Jan 9, 2019 10:44:20 GMT -5
Good, glad you got your replacement and that it's easier to use. Now get to work, we need to see what you do
Post by MsAli on Jan 9, 2019 21:05:54 GMT -5
FA #2 The ryolite? is mostly all gone and I've been studying the flow The top is druze and it pains me to grind it away Cant help it, I love sparkles I am learning you cant just start grinding away on these. It's got some potential
Post by hummingbirdstones on Jan 9, 2019 21:10:40 GMT -5
Get crackin' there, missy! I wanna see what's inside.
Glad they replaced your dremel for you without a hassle.
Post by MsAli on Jan 9, 2019 22:19:46 GMT -5
I'm so happy they did too and so happy I get to finally use the attachments without fear they will go flying across the room
Post by lpl on Jan 10, 2019 10:19:23 GMT -5
Just saw this thread. Those look great Ali!! Can't wait to see what you do with them. And I'm really happy to hear that they replaced your Dremel!
Post by MsAli on Jan 10, 2019 10:35:20 GMT -5
Just saw this thread. Those look great Ali!! Can't wait to see what you do with them. And I'm really happy to hear that they replaced your Dremel! Thank you!
