rockcat11
Member since August 2017
Post by rockcat11 on Jan 5, 2019 10:56:40 GMT -5
Just set up my lortone qt6 for the first time. Iām so nervous! It sounds so different from my nat geo tumbler. I filled it half way with rocks and water ( and grit... haha) and i can hear the water sloshing. Should I add more rocks? I have a good valence of different sizes. Also, the barrel bracket is wiggling a little, making a pinging sound. Is this normal? I tightened it as much as I could.
Post by Fossilman on Jan 5, 2019 11:15:18 GMT -5
Usually around 3/4's full is the rule... Good luck..
rockcat11
Post by rockcat11 on Jan 5, 2019 11:16:41 GMT -5
Usually around 3/4's full is the rule... Good luck.. Should I pop some more in then?
Post by Garage Rocker on Jan 5, 2019 14:33:55 GMT -5
Usually around 3/4's full is the rule... Good luck.. Should I pop some more in then? Yes. The excess noise you hear is rock crashing into rock. You want more of a rolling action inside your barrel.
rockcat11
Post by rockcat11 on Jan 5, 2019 14:45:47 GMT -5
I added some more. Sounds better now and is closer to 3/4 full.
