jimaz
Member since July 2018
Post by jimaz on Jan 19, 2019 22:46:30 GMT -5
I did a forum search a while back on using Airsoft pellets and found several threads. It seems some folks had used them with decent results. I decided to give some a try with a recent run of 500 AO. I used some florescent green Crossman pellets. After two weeks I opened the tumbler and found a layer of “black” fine crud floating on top of the slurry. I’m assuming this was from the pellets as I had no such issues in the earlier stages. It definitely made the clean out more difficult and messy. The pellets were a pain to separate out of the rocks. They appeared to have lost some of their size adding to my assumption the floating debris was likely from the pellets, even though the pellets themselves sink. The rocks came out okay, but I think I’ll go back to the pea sized aquarium gravel in the future.
pizzano
Member since February 2018
Post by pizzano on Jan 19, 2019 22:51:21 GMT -5
No knock on your "experiment".........but I had a chuckle when I read it.........air-soft pellets...........what we do for fun......lol...!
Post by aDave on Jan 19, 2019 22:54:52 GMT -5
I get the same film with plastic pellets. The fact that they float makes them easy to separate and skim off the surface. Can't recall if you use plastic or not, so perhaps you already know this.
jimaz
Post by jimaz on Jan 19, 2019 23:13:09 GMT -5
The air-soft pellets actually sink. If they had floated they would have been much easier to get out of the rocks.
Post by quartz on Jan 24, 2019 23:24:46 GMT -5
I've been using the camo colored ones from Walmart in my 220 run for several years, no floating film, I like that they sink. I've seen a lot less rock chipping and breakage since using them. I use them in my rotary tumblers.
goatgrinder
Make mine a man cave
Member since January 2017
Post by goatgrinder on Jan 25, 2019 12:31:06 GMT -5
But if they are camo how on earth can you see them when you clean out? Heh, heh!
Post by quartz on Jan 25, 2019 23:05:59 GMT -5
Braille
agatemaggot
Member since August 2006
Post by agatemaggot on Jan 25, 2019 23:10:25 GMT -5
Nice ad lib !
