Post by kellykellykelly on Jan 22, 2019 20:45:17 GMT -5
The amethyst crystal is what I want to wrap...how do I make a simple secure wrap with a hook (?) for a chain. A pendant for myself. I have 26 gauge wire - I think I need something heavier- the crystal is 3 cm long and about 1 1/2 wide.
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Jan 22, 2019 22:31:40 GMT -5
Search for cowboy wrap. Probably the easiest.
Post by fernwood on Jan 23, 2019 4:49:59 GMT -5
Check out the tutorials here on wire wrapping. Maybe also do an internet search for wire wrapped crystals. Lots of good photo examples.
Post by hummingbirdstones on Jan 23, 2019 9:31:20 GMT -5
Check out the crystal wrapping tutorials on YouTube. There are gobs of them to choose from.
Post by rockjunquie on Jan 23, 2019 10:05:42 GMT -5
About the easiest way I know how is to bind 3 or 4 wires into a straight bundle, then separate the wires to bring them up along the object. Gather at the top, twist to make a bail and then place your flatnose pliers into the loose wires coming up the object and make a bend to tighten. This is a piece of coal.
lookatthat
Member since May 2017
Post by lookatthat on Jan 23, 2019 10:52:24 GMT -5
About the easiest way I know how is to bind 3 or 4 wires into a straight bundle, then separate the wires to bring them up along the object. Gather at the top, twist to make a bail and then place your flatnose pliers into the loose wires coming up the object and make a bend to tighten. This is a piece of coal. Was that in your stocking?
Post by rockjunquie on Jan 23, 2019 10:54:01 GMT -5
About the easiest way I know how is to bind 3 or 4 wires into a straight bundle, then separate the wires to bring them up along the object. Gather at the top, twist to make a bail and then place your flatnose pliers into the loose wires coming up the object and make a bend to tighten. This is a piece of coal. Was that in your stocking? No, I made them OTHER naughty people.
Post by kellykellykelly on Jan 26, 2019 12:30:05 GMT -5
Thanks everyone!
Post by Fossilman on Jan 28, 2019 10:42:24 GMT -5
Lets see your work, when your finished... Thumbs up
