showet
Member since June 2015
Post by showet on Feb 17, 2019 18:42:46 GMT -5
I am rebuilding an old cabbing machine that has apparently not been used for several years but it all seems to be in original working condition with original parts. It has expanding drums.
A full set of sanding belts of various grits came with the machine. They all appear to be as old as the machine and are in original boxes. The problem occurs when I put one of the old, but unused sanding belts on, start the water, and begin sanding a rock (220 grit.) In about one minute the sanding belt came apart at the seam. I put a second belt on thinking it must have been a fluke, but in about another minute the same thing happened to the second belt. It came apart at the seam.
I am sure these are the correct size belts for this machine and they are turning in the correct direction based on the arrow marked on the belt, and at the correct speed.
So my question is, do belts go old over time and fail because of old age? Or, is there something else to try that might be causing the belts to fail?
Belts are expensive enough that I don't want to keep destroying belts trying to figure out the problem.
{Jokes about things failing because of old age can go here}
NDK
Post by NDK on Feb 17, 2019 20:12:01 GMT -5
In a short answer - yes. I watched a video about a belt grinder and one of the comments was from a guy that had some health issues and didn't use the grinder for several years. Got back into the hobby (knife making) and had several old belts come apart. A 72" belt is probably more of a safety issue coming apart than off a sanding wheel, but no less fun. I'd advise to get new belts.
Post by quartz on Feb 17, 2019 23:43:47 GMT -5
My wife and I ran the rock aspect of an estate sale for the family of a late friend, in the mountain of stuff were lots of belts of indeterminate age. They had been stored dry to the best of our knowledge, but testing showed all were weak in the seam. Gave them away, better than tossing in the garbage.
