Post by fernwood on Feb 22, 2019 7:30:08 GMT -5
After 8 months of using my CE, 3 lb. duel barrel rotary, am having mixed results. Hoping someone has some pointers.
The usual process for hard rocks/cab preforms:
80 SIC Stage
Mix different sizes of rocks/preforms. Add pre-polished, 1/2" triangle ceramic media and/or pre-polished 7 to 7.5 mohs pea gravel.
Add about 4 TBS saved slurry. Add 2 TB new grit. Fill with water to just below the rocks
Let run for up to 3 weeks.
Cleaning
Do a 24-48 hour Borax cleaning of everything. Add about 2-3 TBS Borax and water to the bottom of rocks.
Inspect each rock. Save those that are not ready to move on. Place in bag of water. Those I want to move on which have crystals, I use a toothbrish to remove any remaining grit.
120/220 SIC Stage.
Use ceramics/pea gravel specific for this stage. Add the 4 TBS slurry, 2 TB new grit. Fill with water just to below rock level.
Run 1-2 weeks.
Cleaning
Inspect each rock. Save those that are not ready to move on. Place in bag of water. Those I want to move on which have crystals, I use a toothbrush to remove any remaining grit.
400 or 600 SIC Stage
More ceramics/pea gravel, stage specific. More slurry, grit and water.
Let run 1-2 weeks.
Cleaning
1200 AO Polish Stage
Stage specific or new rock tumbling pellets and/or some stage specific pre tumbled pea gravel.
4-6 TBS slurry, 1 TBS new pre-polish. Fill with water to just below rocks.
Let run 1-2 weeks.
Cleaning
14,000 AO Polish Stage
4-6 TBS slurry, 1 TBS new polish. Fill with water to just below rocks.
Let run 1-2 weeks.
Cleaning
Inspect each rock. Save those that need to run again. Place in bag of water.
The harder rocks are pet wood, fossils, jasper and LSA's. Do some pre-shaping with Dremle on some.
Process is a little different for softer rocks. Less time in Stages 1-2. If undercutting is a concern, then less time in stages 4-5.
Just have a feeling I am missing something here. I do completely wash everything under high pressure between each stage, cleaning and after cleaning. Never let anything dry out.
Thanks.
80 SIC Stage
Cleaning
120/220 SIC Stage.
Run 1-2 weeks.
Cleaning
Let run 1-2 weeks.
Cleaning
Let run 1-2 weeks.
Cleaning
Let run 1-2 weeks.
Cleaning
Thanks.
