spiritstone
Member since August 2014
Post by spiritstone on Mar 4, 2019 17:57:39 GMT -5
This one actually started out so encased in calcite and basalt the only reason I went with it was due to the weight. First step was the acid bath before you see what I found inside on the first pic, even after the acid it looked pretty iffy to me and the first 2 inches broke off from the top. Going to cab one from that piece. After some cleaning up the ugly duck turned out not bad if I say so myself, other then the cracks, I like it. Out of the acid. Pre-polish Finished results today.
Post by beefjello on Mar 4, 2019 19:13:24 GMT -5
This one actually started out so encased in calcite and basalt the only way I went with it was due to the weight. First step was a acid bath before you see what I found inside on the first pic. Even after the acid it looked pretty iffy to me. The first 2 inches broke off the top also. Going to cab one of that. After some cleaning up the ugly duck turned out not bad if I say so, other then the cracks, I like it. Out of the acid. Pre-polish Finished results today. Good call bringing it home and giving it a bath. Nice polish job man!!
fuss
Post by fuss on Mar 13, 2019 23:31:51 GMT -5
very nice.
