harrym
NH - The Granite State
Post by harrym on Mar 14, 2019 7:00:33 GMT -5
I own a supply of both these abrasives and was wondering if its ok to mix them in a stage 3 batch. From opinions I gathered on this board, most folks here prefer AO 500 for stage 3. At the same time, reading books, websites, etc some others prefer using SiC 500 during that stage. What would be the harm if you did 2 tablespoons of one, and 2 tablespoons of the other? Is this question heresy? I looked on line and found that both are 13 microns [ Link: www.kcabrasive.com/sizing/ ] .
Post by fernwood on Mar 14, 2019 8:01:40 GMT -5
Good question. I have SIC 600. Running a batch in them now. I am using the SIC as an experiment for a 6 stage run in rotary. I had done a 5 stage run in the past, but wanted to experiment to see of better results could be obtained.
Hoping more knowledgeable members will check in, but I would not mix SIC and AO.
gatorflash1
Post by gatorflash1 on Mar 14, 2019 12:15:58 GMT -5
Harry -
Try the combo mixture and let us know what you find. They are both very hard and I'm not sure if one would break down the other. My gut tell me SiC is the harder of the two but that is just a guess.
harrym
Post by harrym on Mar 15, 2019 8:47:43 GMT -5
Yeah, I think I'll give it a try. The worst that could happen is I'd have to re-run the batch. I'll let you know - thx
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Mar 21, 2019 5:59:27 GMT -5
harrym
Post by harrym on Mar 21, 2019 10:17:35 GMT -5
Thank you! Saturday is my batch change-out day so I was wondering what I might see, I appreciate the insight.
