sophia13
RIP Jason Strickland, AKA sophia13
Member since March 2018
Post by sophia13 on Apr 16, 2019 8:23:20 GMT -5
Looking for suggestions......if anyone has one. Tough to find deals out here in Georgia.
Post by greig on Apr 16, 2019 9:39:39 GMT -5
Not very helpful, but in my opinion - the best saw is the one you own. ;-) Good luck with your search. Large saws are almost never cheap. I have been looking in my area for something in decent shape for a few years.
Post by roy on Apr 16, 2019 10:36:12 GMT -5
the panther from loreton has done well under my abuse
sophia13
Post by sophia13 on Apr 16, 2019 18:35:30 GMT -5
Thanks Roy, I'll try and find one
sophia13
Post by sophia13 on Apr 16, 2019 18:37:13 GMT -5
I've got a 10" Raytech and an 18" HP. Wanting something in between as I'm working my little raytech a bit tough.
hummingbirdstones2
Vince A., 1958-2023
Member since August 2018
Post by hummingbirdstones2 on Apr 16, 2019 22:26:59 GMT -5
If you stumble across one, the old LS-14 drop saws work okay. They're a bit loud and messy, but if you have a place to set it up where that wouldn't be a huge problem it's a good option. I got a plastic washing machine pan to put under ours, and rigged cut-off shower curtains on PVC pipe to contain the spray.
I really like the vise because it's vertical. Two pieces of vertical all-thread, with the vise plate tightening down from the top. It makes it easier to wedge odd shaped rocks in tightly with pieces of wood. Since there's something on all four sides, I can secure rough chunks that would never work in a standard slab saw vise/carriage setup.
Post by catmandewe on Apr 16, 2019 23:38:04 GMT -5
I like the Barranca Diamond 14" saws but you dont see them very often and of course the Frantoms are Work horses if you can find one.
Tony
Post by johnjsgems on Apr 25, 2019 17:58:29 GMT -5
Barranca HP14 is really built tough although price new is not cheap. Much heavier metal than the Panther so higher to ship at 230 lbs crated.
Post by Rockoonz on Apr 25, 2019 20:09:31 GMT -5
Both of my Highland park 14 inch saws are workhorses. They are running as I type. Original HP, of course, not the new chinese garbage.
