rockytop
Member since January 2017
Post by rockytop on May 10, 2019 21:34:18 GMT -5
I believe this is a grey trapiche sapphire. Any other ideas? All comments appreciated. Thanks. 3 by Steve Gantt, on Flickr
Post by Deleted on May 10, 2019 22:00:18 GMT -5
May be sapphire/corundum, but I don't see the spoked trapiche pattern.
rockytop
Post by rockytop on May 11, 2019 19:59:33 GMT -5
Post by Deleted on May 11, 2019 21:52:03 GMT -5
Ah, that probably wouldn't be a good example with which to compare. I don't see spokes in that piece, either. The 2 lines I see in that piece look more like part of normal corundum crystal hexagonal growth pattern. If it doesn't have wheel-like spokes, then it is not a trapiche.
rockytop
Post by rockytop on May 13, 2019 15:38:58 GMT -5
Any idea what this stone is in that case?
Post by Deleted on May 13, 2019 16:51:04 GMT -5
Any idea what this stone is in that case? It may still be sapphire/corundum (even though not a trapiche). I've seen sapphire cabs that looked similar. If corundum, it should be easy to test. Try a scratch test using a piece of chrysoberyl or topaz. If either of those can scratch it, it is not sapphire.
